ISA SLOTS?
First post, by Cursed Derp
Heyyyyyyyyyo,
I have a Dell Dimension L1000R and I want to know if the machine has ISA slots. I don't really know anything about ISA. I'm only experienced in PCI and a bit of AGP. I REALLY want to get a Sound Blaster 16 to replace my trash PCI 128 card. Any knowledge or insight would be greatly appreciated.
Thank ye all.
I am as smooth as a gravy train with flaming biscuit wheels.
Reply 2 of 14, by Cursed Derp
Would a ISA to PCI slot work for a Sound Blaster 16 ISA card?
Reply 3 of 14, by BinaryDemon
Based on images from a google image search - it appears like you have 4 pci slots. No isa, No agp.
Reply 4 of 14, by Gmlb256
No, the motherboard is based on the i810e chipset, commonly lacking ISA slots. 🙁
ISA slots are 8/16-bit bus whose connectors are usually colored black.
Reply 5 of 14, by BinaryDemon
Cursed Derp wrote on 2024-07-03, 15:30:
Super unlikely. I assume you want better DOS sound. Your best bet would be some PCI SoundBlaster with emulated dos support - Sound Blaster Live! cards were common.
Reply 6 of 14, by Cursed Derp
Thanks. That's disappointing but I'll look into the live cards.
Reply 9 of 14, by BinaryDemon
Both of those are probably fine - take a look at this thread - Sound Blaster LIVE! Versions The consensus seems to be to avoid the SB0200.
Reply 11 of 14, by Cursed Derp
I think I'll go with the 0060 then. Is it a better choice in general?
Reply 12 of 14, by jakethompson1
Just a word of wisdom, if you're like the rest of us it's incredibly likely you're going to end up building another system anyway with ISA, before you compromise with this one 😁
Reply 13 of 14, by ux-3
jakethompson1 wrote on 2024-07-03, 19:08:
But for his current system, a live! would be a great improvement. So it is a good move anyway.
Retro PC warning: The things you own end up owning you.
Reply 14 of 14, by Cursed Derp
Awesome. I'll go with a live.
