Cf card issue
First post, by rain
Hi ive transcend industrial 4 gb cf card but whenever installing from 478 pin mobo windows 98 hangs on install.
But after trying socket 370 mobo everything works well
Bios settings were default.
So is this 478 pin motherboard problem?
_retired retro pc user_
Reply 1 of 14, by ux-3
IDE controller requires driver?
Retro PC warning: The things you own end up owning you.
Reply 3 of 14, by Shponglefan
I've found that CF cards / adapters can be a bit flaky on certain motherboards depending on the UDMA or PIO settings.
I would start by disabling Ultra DMA on the socket 478 setup. After that, if you have the option to set different PIO modes, you can try that too.
Pentium 4 Multi-OS Build
486 DX-33 with 5 sound cards
Reply 4 of 14, by rain
Shponglefan wrote on 2024-07-05, 18:28:
There is no UDMA or pio settings on bios
Reply 5 of 14, by ux-3
can you install with a normal HDD?
Reply 7 of 14, by rain
Any suggestions?
Reply 8 of 14, by MikeSG
At what point in the install does it hang? On reboot?
Reply 9 of 14, by rain
on first "copying files" screen
Reply 10 of 14, by douglar
Are you using a 40 conductor cable or an 80 conductor cable? Is there another device on the cable?
Reply 11 of 14, by rain
douglar wrote on 2024-07-06, 19:46:
Used both. No another device.
As mentioned first post 370 pin mobo works well but pentium 4's not
Reply 12 of 14, by douglar
rain wrote on 2024-07-06, 20:03:
So the odd thing here is that it works on the older system but not the newer system. It’s also odd that it works enough to start the install, but fails during io operations that are still using the BIOS.
Perhaps your P4 is pushing the CF to use a transfer mode that it is not comfortable with, even when in the BIOS.
Can you run speedsys on the pentium 4 and generate the report file at the end? It will likely have the ATA info for the device and list which modes the device supports as well as the date of the firmware. There are other tool like HWINFO that can also pull this info, but speedsys will also give us some thruput numbers that will be interesting. Maybe we can figure out what transfer modes the CF advertises and which one it is using.
Reply 13 of 14, by rain
Yeah it may work i wonder if any other simple fixes
Reply 14 of 14, by technokater
I have that issue too with a couple of my CF cards. I would say it is some kind of incompatibility, either BIOS or hardware. Not much to do besides trying to adjust BIOS settings (if possible) or try different CF cards
