First post, by KIng Mustard
- Newbie
Or would the onboard audio on socket 370 motherboards work fine?
Windows apps do not access the hardware directly. Only through abstraction APIs. If your sound card (or on-board sound chip) has drivers for Windows, then that should be all that you need. So TLDR; yes, Win95 sound drivers will enable Win3.1 apps to output sound when run under Win95, regardless of ISA/PCI.
Turbo XT 12MHz, 8-bit VGA, Dual 360K drives
Intel 386 DX-33, Speedstar 24X, SB 1.5, 1x CD
Intel 486 DX2-66, CL5428 VLB, SBPro 2, 2x CD
Intel Pentium 90, Matrox Millenium 2, SB16, 4x CD
HP Z400, Xeon 3.46GHz, YMF-744, Voodoo3, RTX2080Ti
wbahnassi wrote on 2024-07-06, 10:01:Windows apps do not access the hardware directly. Only through abstraction APIs. If your sound card (or on-board sound chip) has drivers for Windows, then that should be all that you need. So TLDR; yes, Win95 sound drivers will enable Win3.1 apps to output sound when run under Win95, regardless of ISA/PCI.
Fantastic, thank you 👍🏻
