terrorinstinct wrote on 2024-07-11, 21:04:
I would be able to test (and might already have the right caps in my parts bin) but the RF shield is soldered on in about eight places, one of which is right underneath the CRT socket.
Yeah, I know that may sometimes look like a difficult job, but it's actually not that bad at all.
Usually what I do is I take a small flat heat screw driver and start putting a bit of pressure near each soldered tap and then heat it up with the soldering iron. On the first few, I just get maybe a mm or 2 max of separation. After that, the others allow the shield to be lifted more when I heat those taps. Eventually, I circle back to the first few tabs I only desoldered a few mm from and lift them further. I do this several times and the shield comes off after that. The soldered tab on the back of the tube socket is the last one I do / desolder.
You could also use braid or just heat up the solder from each tap and try to drag it away... but I personally find the "lift each tab a little at a time" a little easier.
terrorinstinct wrote on 2024-07-12, 19:52:
Also, what's with those "PROT" diodes that seem to feed into the 80V rail?
Those are there so that in case the output pins on the RGB amp (Vout1, Vout2, and Vout3) go higher than 80V due to a fault (i.e. C106, C206, and C306 go short-circuit), then the diodes will clamp the voltage down to no more than 80V + ~1V max for the diode voltage drop of the protection diodes (i.e. about 81V total.) So in essence, those "prot" diodes are for over-voltage protection.
Why does the 150V rail seem to be tied to the RGB cathode lines in parallel to the cutoff amp's outputs?
Well, the 150V line is not directly tied to the RGB cathode lines. Rather, it pulls up the RGB cathode lines up to 150V DC through the 1 MegaOhm resistors R109, R209, and R309.
Of course, the Cut-Off amp may decrease that DC value to something lower by slightly sinking current on those lines in order to control the base brightness, as mkarcher mentioned.
Finally, you have the RBG video signal coming in from the RBG amp, which is an AC signal and is coupled to the DC voltage above through capacitors C106, C206, and C306). The resultant signal/voltage going to the RGB cathodes is a positive DC voltage bias along with an AC voltage signal on top.
I'm terrible at reading schematics and would like to get better at it so I can stop asking silly questions like these.
Hey, no worries.
Asking "silly" questions is the right way to learn.
Besides, I'm sure you know the saying: there no such thing as a silly question, only a silly answer. 😉
