First post, by manmanbhoy
Hello, I was using dgvoodoo2 with Monster Truck Madness specifically for the frame limiter options which at 20 fps keeps the AI trucks competitive. At higher framerates they cant compete. However as attached, the 3d portion is just blue... Any ideas?
Reply 1 of 2, by manmanbhoy
The frame limiter is working fantastic, also Monster Truck Madness 2 works just fine.
Reply 2 of 2, by Dege
I had some time so gave it a go (Monster Truck Madness Gold) with 2.82.5:
- With hw acceleration enabled it worked perfectly
- For fullscreen software rendering you have to set 'Reduced color mode' to 8 on the exe Compatibility tab otherwise the game does not set a palette to the rendering (I got a plain black screen), and it works perfectly
