First post, by ryulite
i used dosbox 0.63 to open the season of sakura folder but even if i unchecked the read-only checkbox in order for dosbox to access to the folder... because the season of sakura's folder's read-only checkedbox keeps checking itself. what can i do now? 😢
Reply 1 of 4, by eL_PuSHeR
What Operating System and filesystem are you using?
If WinXP + NTFS combo try doing a chkdsk /f
I don't really see what does DOSBox have to do with a folder attributes.
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 2 of 4, by ryulite
sorry but how do i go around keying in that into the H.Games folder?
i am not familar with dos..
thanks
pS: i am using WInXP + NTFS
Reply 3 of 4, by ryulite
how do i go around getting rid of that check using normal ways?
Reply 4 of 4, by DosFreak
Don't worry about read only on the folder. Go into the folder, highlight all of the files, right-click, properties, uncheck read-only on all of them. For some reason RO on folder's doesn't seem to take effect sometimes on the files in Windows.
Make your games work offline
