First post, by Alex_03
- Newbie
Hello
Last week I made a post asking what I/O card to buy to test some 486 boards, I ended up buying a VLB card with a Promise IDE controller and Winbond chipset. I was unsuccessful in getting it to work right away, so I want to work on that.
However the other thing is the 386, it's an odd 386 machine with a built in IDE and floppy controller. I had a 2bg CF card with a bunch of stuff installed working nicely with a CF-IDE adapter. Unfortunately somewhere between using that machine to create a new 500mb bootable CF card with dos for the 486, I now cannot get either of the CF cards to work on the 386. I would like to get the 386 figured out first, since it is what I use to test everything else.
I made sure that the hard drive was set up correctly in the bios, but I get "missing operating system". Another strange thing is that I seem to have trouble booting from floppy, I have a dos 6 setup floppy but it just says "starting MS-DOS" with a flashing cursor for eternity. I have not had trouble with the floppy before.
Thanks,
Alex
