First post, by zuldan
I didn't think it would be this hard to find drivers for this card but I'm at a loss. I believe these are the installation disks (link below). I suspect the installer has to run in Windows, which will then extract and provide the DOS drivers in C:\ISP16. The problem is the installer refuses to work in Windows 95. Here is someone using the drivers https://youtu.be/tadDcNVY8gk?si=bAS9z7BkoANq3dO6. I can see the main exe to initialize the card is in the setup files.
I don't suppose someone would be kind enough to run the setup on their Windows 3.1 install and upload the C:\ISP16 folder?
https://archive.org/details/isp-16v-2-disk-1
The attachment Driver.png is no longer available
The attachment IMG_5658.JPG is no longer available
The attachment IMG_5659.JPG is no longer available
Reply 1 of 6, by darry
I ran the installer in a Windows 98 SE VM. It created an ISP16 directory, which I have attached.
The attachment ISP16.zip is no longer available
The following lines were added to autoexec.bat :
set BLASTER=A220 I7 D1 T4
set ISP16=C:\ISP16
C:\ISP16\ispinit /b
Reply 2 of 6, by Grzyb
What's that "MEDIACHIPS" thing?
"MAD16" suggests some Opti...
Edit: and that "ispinit /b" strangely reminds of Opti's "sndinit /b"...
Kiełbasa smakuje najlepiej, gdy przysmażysz ją laserem!
Reply 3 of 6, by zuldan
darry wrote on 2024-07-13, 03:56:
I ran the installer in a Windows 98 SE VM. It created an ISP16 directory, which I have attached. […]
set ISP16=C:\ISP16
C:\ISP16\ispinit /b
Thank you so much. I couldn't get it to detect the card though. Unless there is some sys file loaded in config.sys thats needed?
The attachment IMG_5661.JPG is no longer available
However, it appears I have the older version of this card and require these drivers Re: Looking for information about ISA Media Magic sound card
Any chance I could get a copy of these?
Reply 4 of 6, by zuldan
I managed to get the installer working on Windows 98 SE as well. The older version of these drivers got the card working.
The attachment IMG_5664.JPG is no longer available
Here are the files including config.sys and autoexec.bat files so no one else has to go through this trouble.
The attachment MMISP16.zip is no longer available
Reply 5 of 6, by Grzyb
Again, looks very similar to the SNDINIT from Opti.
It's likely that generic drivers for Opti 82C929 (or thereabouts) would work as well.
Reply 6 of 6, by darry
Grzyb wrote on 2024-07-13, 09:18:
AFAICR
MAD16 should be an Opti 82C928.
MAD16 Pro should be an Opti 82C929
