First post, by Demolition-Man
- Member
Hi,
Someone posted instructions on our German DOS forum on how you can throttle a somewhat modern retro board using a switch. Thanks again for the instructions, I think the user is also active here.
I have the simplest version, a jumper is switched from the outside using a switch. Switches between 450 MHz and 250 MHz. Already brings improvements to some DOS games. Shut down the PC, press the switch, and turn it back on. What I or we want to know now is what happens if the switch is activated during operation? Nothing? The clock changes? Freeze? Other mischief (reset, or eben damage possible?)? I'm not just pushing it for fun to see what happens. 😉 Does it differ from board to board? What happens with my board (Tyan S1590S) or another one? Thanks!
