First post, by zuldan
- Oldbie
I received this Geforce 256 (Creative CT6970) today and noticed some missing surface mount capacitors next to two memory chips on the back of the card. It looks like someone has just bridged the connections with some solder, really nasty job.
Does anyone know what the specs of these capacitors may be? I'd like to remove the solder and reinstall new capacitors.
Unfortunately, the card is not working at the moment. Motherboard doesn't want to post. There is a component (voltage regulator?) that reaches 105c in about 8 seconds from powering on.
The fan is also missing from the heatsink. I'm guessing there aren't any modern fans that would be compatible?
