First post, by eviledeath
Hello everyone,
I decided to register on Vogon to share my project beyond the linguistic boundaries that I had imposed on myself.
So my apologies, I am absolutely not bilingual, unfortunately my language is French, so some of my messages may not be understandable.
It must be said that Vogon is known for being one of the largest communities on old computer hardware.
Let me introduce myself, my name is Gianni, I am 38 years old and I live in Belgium.
I have been a compulsive collector and a big fan of computer equipment since a young age, falling into it thanks to my grandfather who raised me and there was a dedicated room with 3 Amigas.
Then I quickly switched to a PC with an IBM PS/1 then to an assembled PC (Pentium III 1.1Ghz) and this was the period where I began to handle computer parts.
Now that I have revealed myself a little, I present to you my project.
Some people will take me for a person who has a certain level of madness and I grant you that is completely the case but I love my madness.
5 years ago now I started recovering a lot of old computers around me and through classified ads I told myself that it was not bad to keep the best parts and build systems while respecting the release periods. each material.
I started slowly and little by little I found myself searching classified ad sites looking for parts to improve my PCs because it is obvious that the parts I was picking up were not the most efficient.
One thing led to another and the project naturally migrated into the collection of the largest possible pieces to have and build dream machines faithful to each era.
The stage is set!
The specifications are strict, I need the largest possible PC by December 31 of each year and there is no question of having a part dating from 2004 in a 2003 PC until the date written on the component you start to understand the guy's level of madness 🤣
And since choosing is given up, I sometimes find myself with 4 Dream Machines for the same year.
So sometimes it is difficult to build 1 machine respecting the right period so 4...
I will edit the topic fairly regularly as the project progresses.
For the moment I have decided to cover the years 1986 to 2014 which represents quite a lot of machine.
The last 5 years have been dedicated to research and the accumulation of parts. In 2024 my goal is to 100% complete 3 machines.
**2003 INTEL**
- Case: Antec Plusview 1000 AMG
- Power supply: Fortron FSP350-60PN (PF)
- CPU: Intel Pentium 4 HT Extrême Edition 3.20 @ 3.5Ghz
- Motherboard: Asus P4C800-E Deluxe
- Memory: 4x 512Mb Corsair DDR 500Mhz CMX512-4000PT 3-4-4-8 @ 440Mhz 2.5-4-4-5
- Graphics card: Nvidia FX 5900 Ultra
- CPU Cooler: Intel stock cooler
- GPU Cooler: Nvidia stock cooler
- HDD: 2x WD Raptor 36GB Raid 0
- DVD player: Plextor PX-116A
- Sound card: Sound blaster Audigy 2 ZS Platinum SB0350 + FP SB0250
- Screens: Hercules ProphetView 920 Pro
- OS: Windows XP Pro SP3
Photo file of this Machine --> https://imageshack.com/a/sSi17/1
Reply 1 of 4, by theaellie
ne vous excusez pas de ne pas être bilingue ou que le français soit votre langue maternelle.
This is quite the lovely build. Very fine work you’ve done. Quite spectacular.
Reply 2 of 4, by eviledeath
Hello theaellie,
Thank you for your response and your thoughts on building the 2003 intel dream machine.
To be completely finished, the following things are missing:
- Find a Geforce FX 5950 Ultra (the prices are absurd).
- Buy two Raptor 36Gb to carry out raid0 for the system.
- Assemble and integrate the complete watercooling (CPU + CHIPSET + GPU).
- Find the cable from the front panel of the sound card that I am missing.
- Sheath and cut to length all power cables
- Install white LEDs to light the inside of the box.
- New painting of the case, there are some dents and traces of corrosion on it.
So there are still a lot of things to do so that this construction is 100% finished and can be exhibited at retro gaming conventions.
At the moment I'm working on the AMD Socket 940 dream machine.
I can't find the button to edit my first message, is this normal due to my new registration? or is this not possible? It's quite annoying.
Reply 3 of 4, by eviledeath
Hello everyone,
I took out the boxes with the equipment intended for my 2004 dream machine this beginning of the week, I don't have much time to devote because the preparations for the departure of 2 weeks on vacation.
You won't believe me but I can no longer find my Corsair XMS memory kit purchased last March..., a kit that took me years to find.
It has become imperative for me at this stage of the project to tidy up through the "empty" and to sell/donate everything that is useless, that is to say a lot of things.
Well, I bought several DDR400 Registered memory kits on ebay following the premature death of my SK8V motherboard, thinking with great hope that the problem could come from the ram kit sold with the card...
So I reassembled my Asus SK8V to test it again with the new memory kits purchased in the meantime.
Unfortunately nothing has changed, the card starts the fans running but nothing more, the post-card does not display any codes 😢
I wonder if the bios is not corrupted? I will therefore flash the bios chip to test, the card visually is new and I have not determined any hot spots which would indicate a CC.
Luckily I also have an Asus SK8N in stock that I found on ebay also the card is an after-sales service return which is also new.
Everything is going well for her, the FX-51 too.
At the same time I tested my only stick of XMS Platinum in CAS2 purchased untested on ebay, victory it works well!
Given the rarity of these memories it's really a good thing to have in stock.
JEDEC is well recognized.
Now that I have a functional base I can tackle the integration into the case.
There is a lot of energy to put into making really clean wiring given the number of cables present in the Xaser III
Radiator integration test, the goal here is to modify the case as little as possible while having fairly efficient cooling and remaining with equipment available at the end of 2003, it is imperative!
The Swiftech sits on top next to the front panel, it's just perfect!
For the Blak Ice Micro II you just need to modify the mounting holes of the second fan which do not fall perfectly in the right place.
Now it remains to find the right hardware for the 160mm radiator.
The pump will be a Hydro L-20 12V, the CPU waterblock will certainly be the Asetek waterblock from the L-20 Entry kit or a Swiftech MCW5002-64
The pipes will certainly be Tygon in 10/6 to match the 10mm quick tips, different tests will be done to find the most efficient one, I am afraid that the 10mm will be too restrictive.
The GPU water block will certainly be a Maze 3 from Dangerden or an Innovatek if I manage to find one but you really have to look too.
The rest probably after my vacation at the beginning of August.
Reply 4 of 4, by eviledeath
Hello everyone,
I'll continue to update my thread.
My project is definitely not dead, quite the opposite!
The creation of the non-profit organization should happen soon, hopefully before the end of the year.
In the meantime, I'm continuing to collect the parts to assemble all these superb machines!
Today I received a very rare processor.
The largest Pentium III for the general public.
Not to be confused with the Pentium III-S, which is its 512K server variant.
This processor was only sold to brand manufacturers and never had a boxed version for individuals.
It's the processor I chose for my dream machine from 2001.
Case: Antec SX1240
Power Supply: Fortron 250W or Enermax EG365P-VE
CPU: Pentium III Tualatin 1.4GHz 256K (SL64W, SL6C2, or SL6HR)
Cooler: Thermaltake TR2-M3 + 80mm fan
Water Cooling: Danger Den Cube radiator + 2x 120mm custom copper CPU water block radiators.
Motherboard: Asus TUSL2-C
ASUS iPanel Deluxe
Memory: 2x 256MB PC133MHz@116MHz 2.2.2.7
Graphics Card: ATI Radeon 8500
RAID Card: Iwill SIDE RAID100
HDDs: 2x Seagate ST340016A 40GB IDE
Adaptec 29160 & Tekram DC-390U3W
Sound Card: Creative Sound Blaster Live! 5.1 Platinum SB0060 (Creative PCI128 CT4810)
Front Panel: SB0010
Ethernet Card: D-Link DFE-530TX
OS: Windows XP Pro RTM (October 2001)
Now I just need to compare it to a Pentium 4 Willamette 2GHz.
See you soon.
