Barrel Battery Weirdness
First post, by Joosemachine
Hi All,
I am hoping someone can help me understand this. I have an old 3/486 Jetway motherboard which had a Tadiran non-rechargeable barrel battery (see pic). What is strange though, is if I measure the voltage between the two contacts where the original battery was connected (A and C in the pic) when the board is running, its putting out +5v.. this implies it was charging the battery, even though it was a non-rechargeable.. Does this make any sense to anyone?
Reply 1 of 4, by konc
It looks as if there should be a diode (D4) there to prevent charging and it's missing. A lot of possibilities:
-This version of the motherboard was never meant to be used with a non-rechargeable battery, but the assembler didn't care/know
-The missing components are a manufacturing error
-Someone changed the original battery (a soldering iron has touched the board, see the IC pin between PCB marking C9 and BT1)
-The diode is not missing, but it's D3 and it's broken, very easy to measure
You can't really know, but you are right in this: a non-rechargeable battery shouldn't be there
Reply 2 of 4, by Joosemachine
Thanks for the reply konc! I believe this is the original battery because its manufacture date is 1993, so maybe D3 has just died as you said.. I dont think it would have lasted this long if it was a manufacturing defect or missing component, would it? Wouldnt it have killed the battery pretty quickly if it was trying to charge a non-rechargeable battery?
Reply 3 of 4, by Joosemachine
Another question: I have these green NiMh rechargable batteries which fit perfectly between the "A" and "B" contacts. I measured the voltage here as well, and its also getting +5v. Can I use these to replace the battery and assume the board will keep it charged?
Reply 4 of 4, by Ryccardo
As you've noticed, the charger is little more than a diode and resistor connecting it in parallel with the 5V line, and that will be what determines if a NiMH will last decently or overheat when full on such a basic NiCD charger → https://batteryuniversity.com/article/bu-408- … l-metal-hydride
In other words you may (or may not) have to increase the resistor to further slow down the charge!
And yeah, can't say I've ever seen a PC with a lithium thionil battery, in the mainstream that's an Apple thing 😀
At least it wasn't a Maxell 😁 https://68kmla.org/bb/index.php?threads/warni … atteries.25169/
