First post, by Irinikus
I've had this system since 1994, so it's pretty special to me.
The attachment My IBM 486.jpg is no longer available
For a while I've been meaning to start upgrading it and I've now just had the first opportunity to give it its first of many future upgrades, in the form of a Gravis UltraSound PnP with 2MB of RAM.
The attachment IMG_8683 copy.jpg is no longer available
Here are some shots taken while I was troubleshooting the GUS:
The attachment IMG_8680 copy.jpg is no longer available
The attachment IMG_8681 copy.jpg is no longer available
YouTube
Reply 1 of 88, by Irinikus
I originally had an issue as the CD-ROM interface was disabled in firmware, so I couldn't get the CD-ROM up and running! I initially thought that it might be a jumper setting, but after doing some searching I found that it was indeed disabled in firmware and that I'd need to FLASH the card in order to get the CD-ROM interface up and running.
Luckily I received the Gravis Preparation and Driver floppies, as well as the Applications CD with the card!
The attachment IMG_8690 copy.jpg is no longer available
The Gravis Preparation Disk enabled me to FLASH the card allowing me to enable the CD-ROM interface:
The attachment IMG_8679 copy.jpg is no longer available
YouTube
Reply 2 of 88, by Irinikus
Once I had the GUS up and running, I gave the machine a complete takedown and a deep clean.
The attachment IMG_8685 copy.jpg is no longer available
I was extremely surprised as to how clean the Power Supply was, considering how many years it's been running for! (This pic was taken after I dusted it, but it looks really good on the inside!)
The attachment IMG_8682 copy.jpg is no longer available
YouTube
Reply 3 of 88, by Irinikus
Here's the re-assembly:
The attachment IMG_8686 copy.jpg is no longer available
The attachment IMG_8687 copy.jpg is no longer available
The attachment IMG_8688 copy.jpg is no longer available
To a clean Upgraded Machine!  😎
The attachment IMG_8689 copy.jpg is no longer available
YouTube
Reply 4 of 88, by pan069
Nice. What are the actual system specs, other than that it has a GUS, SB and CDROM?
Reply 5 of 88, by Irinikus
pan069 wrote on 2024-07-19, 21:23:
It's currently a 486 DX4 100 with 32MB FPM RAM, a 520MB hard drive, the GUS PnP and a Quad Speed CD-ROM. (I've removed the Sound Blaster 16-BIT)
Future upgrades include: Installing cache chips, fitting a Pentium OverDrive, installing a Diamond Stealth 64 VLB, replacing the old (INCREADIBLY SLOW!!!) IBM 520MB Hard Drive with an SSD and of cause installing 4MB of RAM onto the GUS PnP!.
YouTube
Reply 6 of 88, by pete8475
Irinikus wrote on 2024-07-20, 05:34:
Future upgrades include: Installing cache chips, fitting a Pentium OverDrive, installing a Diamond Stealth 64 VLB and replacing the old (INCREADIBLY SLOW!!!) IBM 520MB Hard Drive with an SSD.
I love the look of those IBM machines, have fun with the upgrades!
aka pete4237.5
Reply 7 of 88, by creepingnet
DUDE, the IBM PC-330 100DX4 - T/C 6571-XXX - never let that one go. I had one in the early 2000's and it was a beast! I used to run Diablo over Battle.net on it in Windows 98 SE with almost zero lag on 56K Dial-up. I wish I still had it. Those punch pretty far above their weight class.
~The Creeping Network~
Reply 8 of 88, by Irinikus
Thanks! 😎
I love its small form factor and the look of its front panel!
creepingnet wrote on 2024-07-20, 05:42:
Thanks! 😎
I never plan on letting this machine go!!!
YouTube
Reply 9 of 88, by Irinikus
Here’s some information from the system BIOS:
The attachment IMG_8691.jpeg is no longer available
The attachment IMG_8692.jpeg is no longer available
The attachment IMG_8693.jpeg is no longer available
The attachment IMG_8694.jpeg is no longer available
The attachment IMG_8695.jpeg is no longer available
YouTube
Reply 10 of 88, by Joakim
Very nice! I love these small form factor PC:s! I have a similar main dos computer with GUS as well, although a pentium 1 120 MHz. I think i have the exact same sound card. Sometimes I put it on just to run mods on it when I do some solder work.
Such a setup screams for a CRT though! Even if it's quite a hassle to open the computer with it on there it's such a nice retro look and the height of the case is perfect.
Reply 11 of 88, by Irinikus
Joakim wrote on 2024-07-20, 10:16:
Thanks! 😎 Cool!!!
I’d love to get an appropriate IBM 20” CRT (especially when I fit the Diamond Stealth 64 VLB), but they’re becoming increasingly difficult to source locally!
YouTube
Reply 12 of 88, by Irinikus
These are the various jumper settings for the board:
The attachment 046lOh9.png is no longer available
YouTube
Reply 13 of 88, by Irinikus
The attachment wmNR1nT.png is no longer available
The attachment CiO5yJy.png is no longer available
The attachment 7cXkhqb.png is no longer available
The attachment OAD9QPU.png is no longer available
The attachment QBoexFT.png is no longer available
YouTube
Reply 14 of 88, by Irinikus
An interposer is required in order to fit a Pentium Overdrive into one of these machines. This interposer would be pretty much impossible to obtain today, but there is this risky workaround: (Removing a pin from the Pentium Overdrive chip)
The attachment Screenshot 2024-02-09 at 21.32.08.png is no longer available
However, you could mount the chip using tulip connectors, and omit the one that would be slotted onto the pin that must be removed. (A much less risky approach, and the one that I'm going to be taking!)
The attachment SIL_tulip_Connector_2_large.jpg copy.jpg is no longer available
The machine's BIOS is already the LEJT67A BIOS update that's required to run an Overdrive!
The attachment IMG_8693.JPG is no longer available
I'd also have to remove the VRM and insert a jumper block:
The attachment 65g4187-gigaherz-634d81cf26030819607334 copy 2.jpg is no longer available
And set the following jumpers:
The attachment Screenshot 2024-02-09 at 22.26.22.png is no longer available
YouTube
Reply 15 of 88, by theaellie
What a lovely IBM you’ve got. More impressive that you’ve had this for thirty years. Thanks for sharing this wonderful rig.
Reply 16 of 88, by Intel486dx33
I would not worry about motherboard cache 256kb of motherboard cache will only gain you about a 3% Performance boost.
If you really want a performance boost upgrade the CPU to a Pentium Overdrive or Similar.
Also the 486 can not play MP3’s very well or Video, or some games.
Especially if you are going to run Win95
You want a Pentium class CPU if you plan on running Win95
So I would put my money in a Pentium Overdrive CPU and forget about the system cache. 64kb of System cache is good enough.
Reply 17 of 88, by Irinikus
Intel486dx33 wrote on 2024-07-21, 03:24:
I would not worry about motherboard cache 256kb of motherboard cache will only gain you about a 3% Performance boost. If you rea […]
Agreed! 😀
My goal for this build is to get Warcraft II Battle Net Edition to run acceptably well under Windows 98SE.
Besides the 486 CPU, the Hard Drives's also holding this system back considerably, so this will need to be addressed!!!
YouTube
Reply 18 of 88, by Anonymous Coward
Maybe I missed something, but I didn't see any mention of 64kb cache. At least according to the pictures provided there is 0kb cache.
Going from 0kb to anything would yield a very significant improvement (more than 3%).
Reply 19 of 88, by Intel486dx33
Oh, I see. But I would still put my money in a CPU upgrade before the cache upgrade if your on a tight budget.
