First post, by oldhighgerman
Is there any advantage to having a larger/er screen, ok in modern terms, lcd or led, situated further away, over a smaller screen that's situated much closer?
In the 80s studies showed a larger screen cut down on eye strain/fatigue and therefore it was in the interests of productivity for companies to buy big ones. Not that many caught on.
What if situate a 10-13" lcd say 12" or so from your face. Is this still a situation that is less advantageous then a much larger screen (20"+) 20-28" away? Don't hold me to those exact numbers.
Reply 1 of 3, by vstrakh
With age you'll come to appreciate the size and distance.
Unless you have myopia 😀
Reply 2 of 3, by kixs
It's about font size, not screen size. Also sharpness of the text. CRTs had problems with sharpness, while LCDs don't.
Visit my AmiBay items for sale (updated: 2025-10-29). I also take requests 😉
Reply 3 of 3, by oldhighgerman
The font can always be enlarged no matter what you're using.
As far as age, my eyesight used to be extremely sharp, nowhere near as much. I often have to bring stuff closer, or to that optimal distance nearby, in order to see. So I don't know.
