First post, by DeepGalaxyBlue
Hello, I'm rather new to old hardware, but I was able to find my childhood 386 computer in somewhat decent shape so I wanted to ask some questions before I power it on so I won't break anything.
1) The computer has some slight corrosion but at a quick glance it seems cleanable. I happen to have some contact cleaner which is mostly hydrocarbons, would this be OK to clean the boards with or should I get something like isopropyl alcohol?
2) The computer did not come with a power cable but it seems to be compatible with a generic power cable used in PCs even nowadays. Do these old computers need an old power cable of their own, or is any power cable like this fine for them?
3) The computer still has it's sound card and VGA card intact, but it's missing a hard drive. I have seen people use replacements which accept SD card or some kind of card for cameras. Where could I buy one of these and what would I need on my modern PC to write on the card so it would be compatible with my old computer? I'd like the old computer to have MS-DOS on it.
Thank you for your time!
