First post, by Andry
Hello,
I'm getting old and I can't solve a (stupid?) issue about VooDoo2 cards in DOS.
Tried 5 different Voodoo2 cards on three different systems (P100 PCI, P2 333 AGP, K62-450 PCI) using four different main VGA cards (S3 PCI, Rage II+ PCI and AGP, Matrox Millennium PCI)
In pure DOS I get a sort of scrambled color issue:
The attachment 20240727_151403.jpg is no longer available
The attachment 20240727_151342.jpg is no longer available
The attachment 20240727_151324.jpg is no longer available
The attachment 20240727_151318.jpg is no longer available
No problems using Voodoo1 cards.
No Windows test for now (I don't have a Windows ready PC to do the job)
Thank you,
Andrea
Reply 1 of 4, by konc
I believe that for Voodoo2 you need to use the Rush patch, not the same as with a Voodoo1. Have you tried this?
Reply 2 of 4, by Andry
konc wrote on 2024-07-27, 13:57:
It seems not (I also tried more games), but you put me on the right way.
To make it work it is needed to add the following environment variables:
SET SST_GRXCLK=90
SET SST_FT_CLK_DEL=0x4
SET SST_TF0_CLK_DEL=0x6
SET SST_TF1_CLK_DEL=0x6
SET SST_VIN_CLKDEL=0x1
SET SST_VOUT_CLKDEL=0x0
SET SST_TMUMEM_SIZE=2
Thanks for helping!
Andrea
Reply 3 of 4, by Postman5
873739 bytes - the length of this patch TR1
Reply 4 of 4, by Postman5
and glide2x.ovl 212791 bytes - works good with Voodoo2 in TR1
