First post, by cristiansp
Could someone help me?
I'm looking for the driver for a TV card, CIMA ACT lgv-556tv.
Thank you very much
Reply 1 of 8, by weedeewee
google gives me no relevant results on that.
Post photo(s) of the card, with the chip markings clearly readable on the photo(s).
Do not ask Why !
Reply 2 of 8, by cristiansp
I found few results, and the only one that had a download link had a broken link.
Reply 3 of 8, by eddman
You have to help to get help. That name brings up nothing. Is it this one? https://produto.mercadolivre.com.br/MLB-11948 … ic-raridade-_JM
Can't find anything specific for that card but maybe Cirrus' driver would work. They had a software called TVTap; maybe it's for a tuner.
https://edv-janssen.synology.me/html/ct_treib … /5446/files.htm
EDIT:
There is apparently a newer version but cannot find it anywhere. It's insane how impossible it has become to find different versions of Cirrus drivers.
https://web.archive.org/web/19990508210158/ht … p/clgd5446.html
https://web.archive.org/web/20000304002307/ht … phics/5446.html
Reply 4 of 8, by cristiansp
The board is exactly the one in the ad.
Thank you very much for your help.
I downloaded these drivers and the TVtap may indeed be the tuner.
I'm going to install it and hope it works.
Reply 5 of 8, by PC Hoarder Patrol
cristiansp wrote on 2024-08-06, 02:36:
The board is exactly the one in the ad. Thank you very much for your help. I downloaded these drivers and the TVtap may indeed b […]
TVTap was used with a number of these tuner cards...the attached version (v2.04.007an) was available for the pictured Prolink PixelView PV-CL544XP+, and may work with your card...
The attachment 204007an.zip is no longer available
The attachment tv card.jpg is no longer available
Reply 6 of 8, by cristiansp
eddman wrote on 2024-07-29, 12:36:
You have to help to get help. That name brings up nothing. Is it this one? https://produto.mercadolivre.com.br/MLB-11948 … ic-ra […]
EDIT:
I installed the capture card and it worked. Thank you very much for the link. 😁
Reply 7 of 8, by cristiansp
PC Hoarder Patrol wrote on 2024-08-06, 10:08:
TVTap was used with a number of these tuner cards...the attached version (v2.04.007an) was available for the pictured Prolink P […]
Thank you very much. I will download this version. It is newer than the previous one I downloaded.
Reply 8 of 8, by eddman
The one that I linked to, is the installed program actually v1.00?
EDIT: After comparing the dates with the one here, it seems to be v2.00.043.
