keenmaster486 wrote on 2024-07-27, 23:34:
Thanks for the info, that’s useful. Here’s some more context. When I got the CRT it was dim. Dim enough that it was difficult to see in a bright room.
With that context information, I have to adjust my judgement of the situation. While I still blame the beam current limiting circuit for the symptom, the overall low brightness might be a symptom of a tube that's at the end of its useful life.
I figured out how to get the Sony DAS software to talk to the monitor via serial and applied a higher G2 value until the brightness looked normal, [...] how it relates to the “screen” pot you usually find on a normal CRT
G2 and "screen" are two alternate name for the same setting. Some flyback transformers have that pot labelled as Screen/G2. The name "G2" refers to the second grid, starting counting at the anode. This grid is used to control the overall beam current by "screening" (hence the functional name) a fraction of the electrons from leaving the neck part of the tube.
After this it got brighter under most circumstances but began exhibiting the symptom I described in the OP.
So you basically increased the beam currrent to make a dim tube look brighter, and now you get a symptom that looks like some protection circuit kicks in, because the beam current is too high. I no longer think that worn out electrolytics are the root cause, but the whole electronics section operates "as specified" by Sony. So I now suspect you either need a way to adjust the the beam current limit (another parameter in DAS?), defeat that circuit, or you reduce the brightness to an amount that is still considered "OK" by the electronics. Defeating the beam current limiting circuit (which is a safety devce!) is something you should only do if you can judge all the consequences. I am not qualified for that judgement, so this post is telling you about the possibility, but not a recommendation or endorsement to do so. I do no longer expect that recapping has a high chance of improving the situation.
