First post, by smesgr
Greetings,
I'm new here and hope this is the right place for my question. I would like to build an Win98-Gaming-Machine. The setup of K6-II@400/VIA MVP3/256MB RAM/2GB IDEtoCFtoSD-Adapter Hell/ATI Rage IIc works nice now.
Some culpid along the way was the BIOS/Windows/VIA really don't like SD-cards above 8GB. Otherwise it was smooth sailing.
Now I want to reuse my old Joystick found in the basement. The stick itself works fine with 4 Buttons and 4-Axis. But the thing has 8 buttons, one hat and 4-Axis.
Sadly it is hard to find some information of this Joystick. It was obviously only sold in Europe.
What i could figure out of an finding an screenshot of the first page of the manual:
- has two switches 1. toggle between CH / Thrustmaster (labeled C/T). 2. toggle between MS Dos / Windows (labeled A/D) - only A is working for me -> Windows?
- hat seems to work by pressing 3 or 4 buttons at once. e.g. hat forward is 1,2,3,4.
- basement buttons doesn't seem to work, even through good continuity on pcb and switches actual do bridge a connection
I'm 80% sure the joystick was sold with an 3.5" floppy. But the floppy died long time ago and likely was thrown away. Couldn't find any evidence of existence in the net.
Maybe the joystick was sold under a different name elsewhere. But the PCB markings "GC-1000-WD M-PCB" didn't brought up something promising.
The ICs on the PCB are:
- Unknown: ANK0 JP-01A / 404342B42FP / 9725 JAPAN
- Voltage to Frequency: NS LM331M
- Unknown: TI 68C685
- NPN-Transistor: BS66t
besides common R, C and Ds.
Has anybody an idea how to get the full potential of the joystick?
BTW the joystick exists with an Gameport and USB. I'm talking only of the Gameport variant. There seems to exists a P-16 version without the buttons on the base and the switches.
Reply 1 of 5, by dominusprog
Can you post a photo?
Aztech Pro16 II-3D PnP ❇ 8.4GiB Quantum Fireball ❇ Win95 OSR2 Plus!
Reply 2 of 5, by smesgr
sure. Please have look at the attachment.
Reply 3 of 5, by dominusprog
Try this
The attachment drvhu_09-21_p2_driver.EXE is no longer available
Reply 4 of 5, by smesgr
sorry for the long delay. After posting the pictures, I started 3D Bench '00 on the system and killed it. Had to repair the system first.
Thanks for the driver. The driver works in "Windows"-Mode of the joystick but the mapping is off. Thrust is 5/7, ruder is 6/8. The other base buttons don't work.
Reply 5 of 5, by smesgr
finally I got my hands on a working floppy for this joystick
See a floppy image and a picture of the floppy. Hopefully this will help somebody.
This will make all 8x buttons, hat, 2x additional axis work with right switch set to "D" (right position). The left switch "T"/"C" don't seem to do anything.
