First post, by wholover
Hello all! I wanted to say thank you first of all, as I've been lurking on this website for the past few months and it's been by far the biggest help with building and configuring my first DOS/Win3.1/Win95 PC. You guys are awesome!
As for the main meat of this post, I'd like to put a CD drive in my PC, but I have no clue where to start. I tried to connect an IDE CD drive to my motherboard's secondary IDE port via the "master" connector of the IDE cable, but other than some CD spinning (possibly just due to power being delivered to the drive), nothing happened, as my PC ended up hanging between initializing the hardware and loading Win95. I've decided to use the CD drive ports on my CT3780 to connect to a CD drive, but I have no idea what drives are compatible with it. It seems to have proprietary connectors for Panasonic/Creative drives, Mitsumi Drives, and Sony drives, so I don't dare connect any standard IDE drive to that without further research and advice. I'm a bit skittish with doing my research and making sure that things are compatible, since I desperately do not want to fry anything since these components are getting more expensive by the day and I'd feel bad for killing them in general, which I think is understandable.
I have seen previous threads on this website about compatible CD drives for other SB cards, but I don't know if those would be compatible with my card. Can any SB-compatible or AWE32-compatible CD drive work on this card, or does it REQUIRE a CT3780-compatible CD drive? If either are true, is there a list somewhere I can look at? I've been googling around but I haven't found concrete answers. Like I said, I'm skittish, so I decided to ask directly. Any help would be greatly appreciated!
Also, here's a list of my specs in case they're needed:
Processor: Pentium 133MHz
Graphics: Onboard (why use a discrete graphics card if the onboard looks just as good?)
Motherboard: Packard Bell Legend*
RAM: 32MB*
Sound Card: Sound Blaster Awe32 (CT3780)
(I doubt I'd need to list my monitor, keyboard, mouse or FDD but I'll try if needed)
*part number(s) available on request
