First post, by DaveDDS
- Oldbie
Hi guys,
I've got an old Foxconn P4 mainboard that I've fairly recently set up
as a simple DOS system.
It has a network interface (RJ45) on the back panel, which appears to
internally be a SIS900 NIC.
This is what my PCINIC utility shows:
NIC#1 : Bus=0 Dev=4 Func=0
Vendor: 1039 'SIS'
Device: 0900 'SIS900' Rev:90
I/O: 0000E800
MEM: ED103000
IRQ: 0A (10)
I've got three slightly different SIS900 packet drivers:
SiS 900/7016 PCI Adapters Packet Driver Version 1.05 (04/16/99)
SIS900.EXE (22,947 bytes)
SiS 900/7016 PCI Adapters Packet Driver Version 1.13 (1/Aug/2001)
SIS900.EXE (29,125 bytes)
SiS 900/7016 PCI Adapters Packet Driver Version 1.15 (16/Aug/2002)
SIS900.COM (16,397 bytes)
All three "hang" when I try to run/install them - shows the startup
message, then no output and never terminates. (I've tried letting them
sit for several minutes)
If I disable the network adapter within BIOS, all three give:
Error: no adapter found with that configuration
(This is from the last one, it might be slightly different for
the other two, but essentially the same thing "No NIC found"
PCINIC also does not show it.
So, it looks to me like the NIC is there and being detected by the
packet driver - anyone use this NIC with a packet driver?
(Which driver are you using) - anyone have other ideas why it
hangs?
Btw, if I put a Realtek NE2000 compatible in a PCI slot, the NE2000
packet driver loads and works (so hopefully not something else wrong
with the system)
Dave ::: https://dunfield.themindfactory.com ::: "Daves Old Computers"->Personal
https://dunfield.themindfactory.com ; "Daves Old Computers" ; SW dev addict best known:
ImageDisk: rd/wr ANY floppy PChw can ; Micro-C: compiler for DOS+ManySmallCPU ; DDLINK: simple/small filetransfer(w/o netSW)via Lan/Lpt/Com
