First post, by Commonalty
Hello. I have a two compaq portable 3.
Both won't boot and show no screen.
I can see one of them trying to boot from floppy disk. Unfortunately no screen.
I see that there is an RBG output and I connected my Ega monitor.
But maybe you need to create a certain keyboard combo that will use the external screen? Or does it not work with an EGA screen only with a CGA screen?
Who knows?
Or has any possible solution for my black screen?
You're guaranteed to find countless videos featuring sexy plumpers whose asses jiggle like jelly with every thrust. - https://bbwporn.love/ , https://www.bbwtube.porn/6/
Reply 1 of 1, by MAZter
Did you checked manual?
External Monitor
Press and hold the CTRL and ALT keys and then press the < (LESS THAN) key.
Dual-Mode Plasma
Display Selection
Press and hold the CTRL and ALT keys and then press the > (GREATER THAN)
key to return to the plasma display after using an external monitor.
Doom is what you want (c) MAZter
