First post, by acl
- Oldbie
Hi
I recently received a Tyan Tiger MP S2460.
It's a dual socket A motherboard based on AMD-760 MP chipset.
It came with two Athlon MP 2200+
I added 2x 256MB of DDR-266 ECC Registered
Unfortunately, the board only reliably boot with 1 CPU.
Sometimes the second CPU is recognized but freeze after post and can't boot Windows XP
It's fine with only one CPU (tested both)
What i've tested :
- One or two Athlon MP 2200+ -> Only works with one CPU
- One or two Athlon 1400 t-bird (266fsb)-> Only works with one CPU
- Various RAM sticks
- Flashed to the last 1.05 bios from TheRetroWeb
- Lowered FSB to 200
- Cleared CMOS
- Various graphics cards (seems to have an effect because some vga cards can reach the POST more often)
- PCI HD4350 POST less easily than an AGP Intel 740 for example
- No physical damages visible
- Only one or two very slightly bulging capacitors
I must also mention that the previous owner added an extra molex connector soldered to the back of the ATX one to solve a well known issue with this board that could lead to the +5V power cables melting.
Any idea ?
Thanks a lot !
