First post, by JONNY99
So I Just picked this machine up cheap. It checks the ram and posts with the 601-Diskette controller error. Thats as far as it goes. It has one of those barrel battery’s that I snapped off because it was leaking as the always do, but looks to have caused some damage to some traces from leakage. I cleaned the corrosion up and looks better but I’m still skeptical. I’m wondering if that could be giving me problems. It has a header for an external battery that I’m gonna try next. Not sure on which battery I’m supposed to get for it. Also I tried a couple different 3 1/2” drives with the same error. Does it need the bios battery to function at all? I’m wondering where I should go from here.
