First post, by raist
raist
Offline
- Newbie
Hi All!
Some time ago i saw here a PC/104 sound card made by rasteri:
Open Source PC104 Soundcard
And it inspired me to design own card. Similar to the one made by rasteri, but with the wavetable synthesis onboard . CS4237+SAM2695 currently under some tests. Generally works fine in DOS and W98 😀
I wanted to put audio connectors and a game port connector on a external bracket and i used for audio inputs / outputs a JST-PH 2.0 mm connectors - i don't know where i had my brain, but inow i regret it a bit. Guys, do you know where can i find some already made cables? With JST-PH 3pin connectors on both sides, about 20cm length? I tried to crimp such cables by myself - failed it 🙁
Thanks in advance for any advices 😀
BR
Bogdan
