First post, by ux-3
I am wondering if one needs a retro win7 64 or Vista machine?
I do have a potent win XP 32 retro machine and can provide win 10 and 11 too.
So I wonder if there are known games that require windows vista or Windows 7 to run because they fail on XP32 or win 10/11?
Because if no relevant game exists, I could make winXP my last retro PC and don't need to bother with maintaining another OS.
If such games exist, what is the prevalent cause? Something like 64bit and disk protection?
Retro PC warning: The things you own end up owning you.
Reply 1 of 3, by Joseph_Joestar
There are a few edge cases like BioShock, where you need DirectX 10 for the fancy water effects, but still want to retain a degree of EAX support (via OpenAL and/or Creative ALchemy) for improved sound positioning and reverb/occlusion effects. You can accomplish this by running that game under Windows 7 while using an X-Fi sound card. I'm not sure how well X-Fi drivers work under newer Windows versions (beyond Win7), but maybe someone else can chime in.
There are also maintenance benefits for dual booting WinXP with Win7. The latter allows you to use USB 3.0 and larger (> 2TB) hard drives. This is useful for easily transferring GOG offline installers from an external USB 3.0 HDD to your WinXP drive, for example.
My retro stuff
Reply 2 of 3, by leileilol
The original release of Halo 2 probably.
long live PCem
Reply 3 of 3, by GemCookie
InkBall is bundled with Windows Vista (and Windows XP Tablet PC Edition, if you can get a hold of that). It won't run on Windows 7.
Joseph_Joestar wrote on 2024-08-05, 08:58:
My Core 2 Quad PC has a Via USB 3.0 controller with Windows XP drivers. Hard disk drives up to 17.5 TB in size should work as long as they use 4 KiB sectors.
I've had the time of my life
I've never felt this way before
Yes, I swear, it's so true
I'm holding onto used hardware
