First post, by kotel
Hi
Just now I got this Asrock SATA K7VT4A PRO. Sadly the VRM coils (L3, L2 and L1) were cut off, rendering this board useless. The question is, will VRM coils from boards bellow work here or what are the specs of the inductors?
Intel D865PERL
MS-7366 V3
MS-7399
Fujitsu D1520
"Sent on a mission, to protect the last treasures. Through struggle and strife we can see the light. Even if our mission is partially complete, Our efforts are not in vain.
Let that be our legacy."
-Stronghold 5-5
Reply 1 of 12, by kotel
For L3 and L1 I took the VRM coils form Fujitsu D1520 and for L2 I took from a dead PSU. How stable it is? No idea as I'm currently testing this board. Sadly the board doesn't detect AGP cards, but considering how much damage there was on NB I'm surprised it even works!
-Stronghold 5-5
Reply 2 of 12, by majestyk
kotel wrote on 2024-08-10, 15:30:
How stable it is?
It´s hard to guess the exact electrical parameters of the inductors without any(!) pictures provided.
Reply 3 of 12, by kotel
Pictures of L3 and L1 are in attachments. For L2 its gonna be hard to guess since its covered by a heat shrink tube, so I didn't bother taking a picture. Currently the board undergoes stress tests. Now theres another problem, that is more serious than a dead AGP slot, atleast for me. The CMOS doesn't keep the changes. Battery is new and measures 3.2V. I can see the same voltage when I measure in the board.
-Stronghold 5-5
Reply 4 of 12, by Horun
If this is your board: https://theretroweb.com/motherboards/s/asrock-k7vt4a-pro
Those two coils you picture do not have enough windings compared to the TRW picture of L1 and L3, so their Inductance will be far less and might cause major ripple under heavy cpu load.
As for the AGP check the volts on Q16, think it supplies the 1.5v for the AGP...Just a thought.
Reply 5 of 12, by kotel
Horun wrote on 2024-08-10, 18:09:
Thank you for the reply. Yes I do understand that the coil has not enough windings, but its not like I will game on it due to the broken AGP slot. I think the cause for the dead AGP slot will be missing connections from and to NB. What I don't know is the cause for the CMOS not keeping settings.
-Stronghold 5-5
Reply 6 of 12, by Horun
Does it keep time ? The SB VT8237 has the RTC and cmos ram. Maybe the CLRCMOS jumper or traces is shorting somewhere...
Probably unrelated but One of my VIA based boards had issues with savings settings and it was the EEPROM where the ESCD stuff is stored, it had been written too so many times that portion of the eeprom went bad. Replaced it and all good...
Reply 7 of 12, by momaka
kotel wrote on 2024-08-10, 18:30:
It doesn't really matter if you will game on this board or not or even if you just plan to use it "lightly".
For starters, socket 462 CPUs don't have the idle power saving features/states that the equivalent Intel CPUs had at the time. As such, socket 462 CPUs pretty much run full-tilt both in idle and under 100% load. The difference is usually about 10-20% difference in the power consumption, if even that much. For example, an Athlon XP 2500+ system of mine uses about 100 Watts in "idle" mode and 117 Watts under 100% CPU load. The only way I can make a dent in the power consumption of that system is when I swap the CPU with something less powerful, like my Duron Applebred 1400 (T-bred "B" core), which has a max TDP of 54W (IIRC) compared to the almost 80 Watts of the 2500+.
But anyways, all I'm trying to say is you need to get the right inductors / coils from the start for the board to run right.
That being said, the inductors you chose for L1 and L3 (the toroidal ones near the CPU) appear to be more or less close enough to what was there originally, at least compared to the pictures on the board from TRW.
HOW TO PICK EQUIVALENT INDUCTORS:
1) The core type of the inductor must match.
I'm not exactly sure what that light-green core's parameters are. But if my memory serves me right, the Xbox 360 motherboards used those and the all-black toroidal inductors almost interchangeably between various designs, so they must be closely related. The all-black cores should be Micrometals -45 type core. It's a popular core type that was on many motherboards of that era (Pentium 4 / Athlon XP / Athlon 64), especially on ASUS and AsRock motherboards.
2) The inductor windings must be relatively close to the originals in terms of (equivalent) thickness. In regards to that, the replacements you used appear to have only 2 wires, whereas the originals seen in the picture on TRW appear to have 3 wires. Otherwise, the # of turns appears to be the same (I'm counting 4 turns for your replacement coils and also 4 turns from the picture on TRW.) And given the core appears to be the same type, that should be making the inductance the same. Only the wire thickness is smaller on your replacements. This means the inductors will heat up more at higher currents compared to the originals. To make sure you don't over-heat them, use a CPU with a lower-rated TDP (lower power dissipation).
As for L2, I'm guessing that's the one in the upper-right corner of the motherboard near the ATX connector? If so, that one isn't too critical to match, especially when it's a "rod" type rather than a toroidal one, like the two near the CPU socket. All that L2 does in this case (assuming the above assumption is true) is filter out EMI/RFI from the CPU VRM to get back to the PSU (and the rest of the components in the computer.)
majestyk wrote on 2024-08-10, 16:15:
Agreed.
For these kind of questions, pictures should always be provided.
Not to sound too harsh here, but I really don't understand how people expect anyone to know the exact answer to their very very specific technician-type of question without providing any pictures. Electronics repair is largely a "must see with my eyes" type of work. Not providing pictures is just not serious. It's the equivalent of calling your doctor and telling him/her you have a cough and then expecting them to know exactly what medicine or treatment to give you based on that . Sorry, but it's not gonna work. Either the doctor needs to see you or you need to describe your symptoms very very precisely for them to get even a remote idea of what the problem might be. Going back to the question in hand in this thread, you could have done this by at least describing all of the inductors' parameters (size, color, # of turns, # of wire strands, and etc.) on all of the motherboards you had available for parts. Of course, at that point, you might as well snap a few pictures instead. Or as the saying goes "a picture is worth a 1000 words". For some of these technical questions, it can be worth even more.
Again, forgive me if I sound harsh and long-winded here, but it just really irks me when I see HW troubleshooting threads without pictures, especially when it comes down to component-level troubleshooting.
Horun wrote on 2024-08-10, 20:12:
Good call.
I think I've read about this issue / remedy once on badcaps too, so it's probably not that of an uncommon issue.
Reply 8 of 12, by Horun
Yeah I see the 3 wire windings and about 18 wraps for 6, versus 2 wire and 8 for 4 overall. That be 2/3 the inductance if same core.....thick wires just allows more amps...just an observation 😀
Reply 9 of 12, by kotel
Forgot to mention it also doesn't keep time. Looked on both sides of the PCB to look for missing/shorted traces and only found one chiped and missing ceramic cap under the NB. Ill try to replace it and see what changes. Everything is normal if I set the time and date with settings while the mobo still recives power. After I cut the power it resets to defaults (with time settings) Its just like the battery wasn't there, but it is. Sorry, I'm used to forums with less experienced users (where they mostly say bad retro board = trash) so I can sometimes be hard to understand/misunderstood.
Thank you Momaka for the tips on choosing correct coils.
-Stronghold 5-5
Reply 10 of 12, by Horun
Hmm so maybe the battery + is not getting to the vt8237. TRW has the datasheet: https://theretroweb.com/chip/documentation/ds … 3b308182098.pdf
I would double check around the coin cell to make sure the battery + volts and ground is getting to traces. Then try to find pin AF04 of the vt8237 and see if 3 volts are there.
Reply 11 of 12, by kotel
After replacing the missing cap (without replacing the chiped one) there wasn't any improvement. After some time the CMOS issue went away. Keeps time after 2+ hours. Currently gonna see if it can hold the settings for a day, then a week, then for a month. I understand that the SATA controller only will detect SATA 1 based drivers?
-Stronghold 5-5
Reply 12 of 12, by kotel
For future people with the same issue, the best coils would be from an MSI 845PE NEO V3. The are pretty much the same (same thickness of wires, 3 windings) but their color is yellow.
-Stronghold 5-5
