First post, by MaverickUK
- Newbie
I have a Toshiba Libretto 100CT that I've enjoyed for many years, but unfortunately the display has finally failed
Although it's possible to find replacement Sharp LQ71Y03 panels still, such as from https://www.elecok.com/sharp-lq71y03-7-1-a-si … -lcd-panel.html I would rather replace it with something newer that will look better and hopefully last longer.
I've been trying to find information about the type of connection used on this laptop, but I couldn't find enough detail in the service manuals for it. The best I found were suggestions it could be Low-Voltage Differential Signaling (LVDS) or Parallel TTL (Transistor-Transistor Logic)
After watching https://www.youtube.com/watch?v=vvn2lBFhioQ I've decided to try a simular approach and tap into the VGA output on the expansion slot bus.
To experiment with I've ordered:
- A modern 7" LCD: https://www.aliexpress.com/item/1005005292813240.html
- A 50 PIN driver board that accepts a VGA signal: https://www.aliexpress.com/item/1005006164948575.html
At the moment my concerns are
- That it won't be possible to get a VGA signal from the expansion slot pins
- That the LCD panel won't fit in the case
- It might be tricky getting a suitable voltage for the controller
- Even if everything else works - that I'll be able to fit a suitable controller inside the laptop
So overall it feels like a bit of a moon shot, but hey... gotta try these things, right?
Very open to suggestions or advice from those with more knowledge in any of these areas
- HDD Synth - Recreates the sound of mechanical spinning HDD
- GameMinder - DOS games launcher
