First post, by Anonymoose
I’m aware that this topic has been brought up a lot, but nothing seems to work for me. I have a Dell Dimension L600R, a generic Pentium 3, and per the subject, it just hangs on the shutting down screen whether shutting down or restarting. Restarting into msdos mode just hangs on a black screen.
I’ve tried searching for ACPI in the bios (it wasn’t there), installing the Win98 shutdown supplement, disabling it in the registry, and I happened to come across a post where turning off usb support in the bios fixed it, and that didn’t work either. Any thoughts?
Reply 1 of 12, by Harry Potter
Well, I have the same issue on my Win98SE tower. It has a Pentium 4. For now, I'm just cutting the power to the computer. I don't think I'm having your other problems, but I've been having other problems, including in DOS more or DOS under Windows. I'm sorry I wasn't helpful. 🙁
Joseph Rose, a.k.a. Harry Potter
Working magic in the computer community
Reply 2 of 12, by myne
Updates?
windowsupdaterestored.com
I built:
Reply 3 of 12, by Anonymoose
Harry Potter wrote on 2024-08-13, 11:48:
No worries! Always good to know I’m not alone in this problem. I could just boot into dos to remedy that problem and just continue cutting the power to bypass the shutdown issue.
Reply 4 of 12, by Namrok
Every time I've had this happen, it's some driver that doesn't want to unload. On my Windows 95 box the latest Nvidia reference driver for the Riva 128 causes it. One way to help narrow it down is to press F8 when windows is booting, and choose the option that generates bootlog.txt. Normally this is used to troubleshoot why windows is failing to start up properly, but it also logs drivers being unloaded on shutdown too. At least, I'm pretty sure it does, it's been a while. So turn on your computer, hit F8, generate the bootlog.txt, then have Windows shut down again. See if it gets stuck on a driver it's trying to unload.
Win95/DOS 7.1 - P233 MMX (@2.5 x 100 FSB), Diamond Viper V330 AGP, SB16 CT2800
Win98 - K6-2+ 500, GF2 MX, SB AWE 64 CT4500, SBLive CT4780
Win98 - Pentium III 1000, GF2 GTS, SBLive CT4760
WinXP - Athlon 64 3200+, GF 7800 GS, Audigy 2 ZS
Reply 5 of 12, by Harry Potter
I have tried the file before to see what was causing problems at startup but couldn't find it. 🙁 Where would it be located?
Reply 6 of 12, by Namrok
For me, when my computer would hang on shutdown, I just checked what the last line was. I believe I saw that it was attempting to unload some nvblahblahblah.vxd file associated with my Riva128, but I never saw confirmation it unloaded. So I assumed that was my problem. Installed some manufacturer specific drivers from Diamond and my problems went away.
Reply 7 of 12, by Harry Potter
I don't know where the resulting file is located. I tried using DIW/S/B BOOTLOG.TXT but didn't find it. 🙁
Reply 8 of 12, by Namrok
It should just be in c:\bootlog.txt
Reply 9 of 12, by Harry Potter
Oh. Thank you, and sorry for the stupid question. 🙁
Reply 10 of 12, by andre_6
From personal experience, for me it was either related to USB or Creative Live! drivers
Reply 11 of 12, by chinny22
My experience is windows shuts down ok until I try applying updates
but it's definitely not 1 single thing that causes it and is a matter of finding the right combination specific for your setup
Reply 12 of 12, by Renaissance 2K
I had this issue for months, and it randomly resolved itself last night after installing DirectX 9.0c to fix an unrelated issue.
