First post, by rmay635703
I have several high end screens with vga including a CRT that handles 2048x1536
None of my adapters go that, maxing out at 1920x1200 on the high end.
I’ve noticed some Chinese sellers pushing a little thing that looks like a box instead of a dongle that has 4k plastered all over hdmi-VGA.
Do any of these actually do this or is this a downconverter or just a lie?
I have a strange 1440p screen that lacks hdmi and would like to test a wide screen resolution above 1920x1200, maybe 2560x1200 but not sure if any name brand adapters (common) support above FHD on VGA using an hdmi or mini display port.
Reply 1 of 2, by debs3759
I'm pretty sure 2048x1536 is the highest resolution in the VGA specs. Beyond that, it has to be other outlets (eg DVI maxes out at 2560 x 1600, etc)
Reply 2 of 2, by rmay635703
debs3759 wrote on 2024-08-13, 20:07:
2048x1536 would be delightful but there are only 2 adapters hdmi->vga that reliably go that high and I haven’t found one for sale
Without adapters a few folks have direct driven them that high manually
https://m.youtube.com/watch?v=zbQbxcWIzB0
Well I tried getting something higher than 1920x1200 and was able to get 2160x1200 using the nvidia control panel.
Trying to increase the vertical resolution seems to just cause “no signal “ which was the problem I had before.
Much past 2160 also gets no signal. Ah well it’s a very small improvement, really had to tweek the horizontal position and size to get it working.
Oddly I tried custom settings before but the nvidia control panel used to crap out using custom timings across multiple screens
