First post, by ayuwea
Hi everyone!
I´ve decided to build a little DOS-Win98 machine and I need some advice about the psu.
Case: Morex 2699. My plan is to mod the case and fit 2x4cm + 1x9,2cm fans http://silent.gumph.org/content/4/7/011-cubid … 99r-review.html
MB/CPU: VIA Epia M (C3 Nehemia CPU) https://theretroweb.com/motherboards/s/via-epia-m
Hard Drive: Hitachi 2,5" 100Gb 5400rpm with 44-40 pin adapter
Sound card: Yamaha XG 7x4 (not bought yet)
IGPU: Integrated VIA S3G Unichrome Pro
*GPU: I´ve already bought dual PCI riser, so I´d like to try to fit a Voodoo 2 3000 PCI in this case.
Bays:Slim CDROM + Slim Floppy Disk
PSU:???
I was expecting to add a flexATX PSU, but there´s not enough room between motherboard and front panel. I´m not sure how much current are components taking from 3,3V and 5V rails as the MB doesn´t have the 12V CPU connector. These are the options I´ve found, but I don´t know if they´re enough:
- PicoPSU 20pin 120W https://www.mini-box.com/PicoPSU-120-WI-25-12 … TX-power-supply
6A (3,3V), 6A (5V), 6A (12V)
- DC-DC PSU 160W https://www.mini-box.com/M2-ATX-160w-Intellig … =8&category=981
8A (3,3V), 8A (5V), 8A (12V)
- HDPlex 250W https://hdplex.com/hdplex-fanless-250w-gan-aio-atx-psu.html
10A (3,3V), 10A (5V), 20A (12V)
Are any of them suitable for my build? Do you have other recommendation?
Thank you!
