First post, by vfxsup
I have a 486 with the following sound cards in it:
1. PicoGUS in MPU-401 mode (330, IRQ 2/9)
2. SB 1.5 (IRQ 7)
3. Pro Audio Spectrum 16 (IRQ 11)
The SB and the PAS16 work well. Outputting anything over the PicoGUS/MPU-401 freezes the system. Removing the PAS16 and the PicoGUS/MPU-401 suddenly works perfectly.
The PicoGUS is running the latest firmware (2.0.0) and pgusinit (3.0.0). Jumpers are set to IRQ 2/9 and DMA disabled (tried it with the DMA enabled, didn't make a difference).
PAS16 is configured in the config.sys as follows:
device=c:\pas16\mvsound.sys d:5 q:11 s:0 :m0 :j0
mvsound.sys is the latest version 3.26.
Running proas.exe seems to confirm that the MPU-401 emulator is disabled on the PAS16:
MPU 401 Emulator Information: Active: 00 Port: 0330 IRQ: 00 […]
Active: 00
Port: 0330
IRQ: 00
First I've thought that this might be the same problem as Problems with Pro Audio Spectrum 16 and PC MIDI clone card but using the latest mvsound.sys didn't fix it. Anyone has an idea where to look next?
Thanks!
