First post, by psaez
How to view pictures of a folder in Windows 2000 like in Windows 7, 10, etc.. moving between pictures with arrow keys
When I open a folder full of photos, I can open only one picture, and I can't move left and right to see the other pictures.
Which safe and secure application should I install in windows 2000 to be able to see all the pictures and move between them like we do nowadays?
Reply 1 of 11, by RandomStranger
IrfanView. It's a fine image viewing program with some minor editing options. Small, light weight and works in almost everything at least upwards from W98, maybe on W95 too, I don't remember trying it. I've been using it on all my Windows PCs for over 20 years.
Reply 2 of 11, by psaez
RandomStranger wrote on 2024-08-18, 20:06:
Which version for windows 98 and 2000?
Reply 3 of 11, by RandomStranger
Version 3.0 introduced Thumbnails, I usually stay on 3.0 or 3.6 for retro PCs, but I think it supported W98 up to 4.40 and there were still some good feature updates for Thumbnails past 3.6, but that was never particularly important for me. And I'm not sure, but I think XP is still supported to this day.
Reply 4 of 11, by Ryccardo
psaez wrote on 2024-08-18, 20:42:
4.44 is the maximum for NT/2000/all 9x 😀
Reply 5 of 11, by akimmet
Old releases of XnView may work as well.
Reply 6 of 11, by Jo22
Mystic Thumbs comes to mind. Screenshots can be seen here. Not sure if it runs on Windows XP and below, however.
I've used it in the Windows 7 days, to get back Windows XP type of thumbnails.
Edit:
Ryccardo wrote on 2024-08-19, 16:04:
Reply 7 of 11, by Ryccardo
Jo22 wrote on 2024-08-20, 03:44:
(using KernelEx)
Wrong side of the ship of Theseus 😀
Reply 8 of 11, by psaez
i tested it, but is very slow. I'm using v4.44. Do you think that if I use an older version will move between images faster?
Reply 9 of 11, by RandomStranger
It's very light weight, it shouldn't be slow. I don't think there will be any significant improvements on older versions.
Reply 10 of 11, by bakemono
To make thumbnails in irfanview come up more quickly, you could try going to thumbnail options and choose a smaller thumbnail size, uncheck 'use resample...', and check 'try to load EXIF thumbnail'
Wreckage reimagined on itch: https://90soft90.itch.io/wreckage-dash
Reply 11 of 11, by psaez
bakemono wrote on 2024-08-27, 19:38:
it's slow when moving between images, not previewing them on the folder
