First post, by Nemo1985
Hello people, I own 4 different Savage 4 cards but apparently noone of them works fine apparently.
I tried them on 2 different computers:
1) Sis universal agp chipset where I test all my agp cards.
2) Abit BE6-II with 440bx.
I tried the following driver versions on windows 98 se:
4.11.01.8008 ERD
4.12.01.8226
treiber-savage4-w9x-8.20.38
I tried to disable the video chacheable system in the bios just to be safe.
First card is: DH-Savage4
Picture: https://www.picclickimg.com/KQ0AAOSw~MllS8AW/ … vage4-LT-8.webp
It claims to be a Savage4 32mb.
Clock: 110/125
This one crashes with this error on windows 98 (works fine in dos):
The attachment photo_2024-08-19_05-51-03.jpg is no longer available
Second card: Diamond S3 Savage4 pro 8mb with no heatsink
Picture: https://i.ebayimg.com/images/g/IUkAAOSwxqZjIYXu/s-l1600.jpg
Clock: 120/100
This one crash on windows 98 before the desktop, the screen is balck with hourglass mouse cursor not moving.
Third card: Diamond Stealth III 540 16mb AGP Savage 4
Picture: https://www.vgamuseum.info/images/palcal/diam … nd/ds3s540b.jpg
Clock: 125/125
This card was able to boot fine in windows after I installed the driver but then hanged after 3 seconds.
Fourth card: Number Nine Savage 4 with 16mb of sgram
Picture: https://upload.wikimedia.org/wikipedia/common … 2886C398%29.jpg
Clock: 143/153
This one keep sending the lcd monitor out of range, but when I was able to boot on windows it worked fine.
What's wrong with those cards? Clearly something is wrong but the chance that 3 out of 4 are broken (after having bought them as working), it's quite sketchy.
Reply 1 of 6, by Joseph_Joestar
Nemo1985 wrote on 2024-08-19, 04:13:
Try the A-Trend driver CD from Phil's website.
I had similar issues with my own Savage4, and only those drivers turned out to be stable for that particular card. Install them manually via Device Manager if the automated process doesn't work.
My retro builds
Reply 2 of 6, by Nemo1985
Joseph_Joestar wrote on 2024-08-19, 04:17:
I had driver issues with my own Savage4 and only those turned out to be stable for that particular card. Install them manually via Device Manager if the automated process doesn't work.
Ok I tried the drivers:
First and second card still doesn't work, black screen after installing the drivers.
Third card made to windows but when I tried to load incoming benchmark hanged
Fourth card worked fine.
A small update, I tried to update the bios of the 540 card, it works fine for like a minute and then hangs, now it did twice just after loading the incoming benchmark again, bluescreen and error in 06 0007:00006156.
The address always change, I also tried another stick of ram (just to be sure) but same error, definitely those cards have some quirks.
Is it possible to test the video ram in dos? Because there they work without any issue.
Reply 3 of 6, by The Serpent Rider
Go into Windows GUI acceleration and set the slider to 2/4 or 3/4, instead of 4/4.
Reply 4 of 6, by Nemo1985
It's a mistery, now all cards works fine with the driver downloaded from Phils website, no need to move the Windows GUI slider.
To clean some mess about the Savage4 versions I added the core and memory clock to the first post.
Reply 5 of 6, by eliot_new
This is good to know, as I m thinking about a Savage4 card. I will tell you the results as soon as I buy and install it.
DOS:K6-3/400,192MB,P5A,Rendition v2200 AGP,Trio64 PCI,3dfx V1,AWE64,ESS1938,PicoGUS,32GB
w98SE:P3/450,768MB,QDI440BX,V3AGP,AWE64,PicoGUS,80GB
wXP:P3/1G,512MB,CUSL2-C,MSIFX5600,Audigy1,80GB
Reply 6 of 6, by Pidalin_CZ
Hello people, I own 4 different Savage 4 cards but apparently noone of them works fine apparently. I tried them on 2 different c […]
4.11.01.8008 ERD
4.12.01.8226
Clock: 110/125
Clock: 120/100
Clock: 125/125
Clock: 143/153
Hi, it's older post, but I will add my experiences, in last few years, I also collected 4 different pieces of S3 Savage 4, all different models and the same result - non of them worked properly, this chip must be totally bugged, no wonder that S3 doesn't exist anymore.
I tried literally all different drivers I found, different computers, all possible settings in bios and nothing helped, only thing that is good about these GPUs that when you use it for DOS, it runs in 75 Hz in 640x480 games like Warcraft 2, which is nice on CRT, but only 3 of 4 pieces had this feature, so it's not universal, it must be something in bios.
I give up with this card, it's just bugged crap good only for collectors, not for actual retro fun, because it's not fun.
First piece I had started 3D mark and games fine, but it started freezing after like 1 minute (no, it was not because of temperature), second piece the same result, third and fourth piece behaved a little bit diferent, 3D or OpenGL didn't work at all. Once I passed 3D Mark 99 on 3rd card, but only once and I have no idea how I did it, probably just luck. But it looks like it has something to do with DirectX, I think it made difference when I installed DX8 first and DX9 next, maybe this card just hates when DX9 is installed or something, I don't know.
