Nemo1985 wrote on 2024-08-23, 01:10:Thank you for the patience and the explanation. I'm sure the eeprom reader worked with 28 pins because I flashed some video bios […]
Thank you for the patience and the explanation. I'm sure the eeprom reader worked with 28 pins because I flashed some video bios in the past (S3 virge and SIS).
That being said I did the test you asked:
That's the actual orientation of the board:
The attachment photo_2024-08-23_02-54-09.jpg is no longer available
- There is no continuity from pin 5 to the left side of r614 (there is on the right side though)
- When I measure from Pin 5 to left side I have 2,212kOhm, same when I measure from left to right side of r614
- No continuity between the R614 and any pin of g14 (the right has 2 pins, left 1)
- In diode check mode with black tip on top and red on bottom I get v2.590, while if I do it with G13 I get something around v0,7
- I get a value between v2.1 and v2.2
- I do get continuity between those two points
I should have added another sentence about the orientation I used to describe "left", "right" and so on. They was specifically referring to the last image in your imgur album, which is 180 degrees turned to the "actual orientation" you are showing now. I will change terminology now and refer to the "actual orientation" image. So it is correct that continuity from pin 5 of U24 is to the right side of R614. R614 is at the top of the three resistors. If you get continuity from pin 5 to the bottom resistor, there is a short between R612 and R614. The resistor you probed is OK. If there is no continuity between R614 (the top resistor) and any pin of G14, there is a broken trace, or I reversed engineered the PCB wrongly. The left side of the resistors should be connected (via thin traces) to the bottom right pins of G14 (top resistor), G13 (center resistor) and G12 (bottom resistor).
The correct test points for G12, G13 and G14 are: red probe on the bottom right pin, and block probe on either other pin. You did get 0.7V on G13, showing that the test method works for the top right pin and you actually get around 0.7V. The defiation on G14 is indeed suspicious.
I think your hypothesis is right, g14 is broken.
After looking at the schematics, it seems that G14 might break if you insert a broken 28-pin chip that has pin 28 and pin 14 shorted, or if you insert a 28-pin chip 180 degrees turned around.
I'm definitely not confident on desoldering such small components, but I may ask someone to do it. Do you suggest to swap G14 and G15, or should I get a new BC848 (I live in Europe)?
This one would work? https://www.ebay.com/itm/303984111153
The idea of swapping the transistors was suggested a as temporary solution, in case you don't want to or can not get a replacement transistor. Also, you can swap first to try if it solves your issue, and postpone replacing the broken transistor until it is convenient. This is most notable if you could do the swap (or just remove G14 and move G15 to G14) yourself, as for a person experienced with SMD soldering, this should be completable in less than 30 minutes, so it's an easy thing to get started and verify that we are on the right track. On the other hand, as you need to ask someone else to do the soldering, I would recommend you get confident in understanding the issue(s) with your device, so all issues can be solved at once as a permanent solution. So if it turns out that G14 is the only problem (G12 and G13 behave the same way on the meter, but G14 is different, and all traces are OK, and then you get someone to swap G14, you can be quite confident you don't have to ask again for another minor fix. In your situation, arranging the work might be just as cumbersome as the work actually being performed, so it's best to get it right from the start.
If the someone you can ask to swap the transistor performs SMD soldering often, chances are that this person already bought a bag of 100 "standard NPN transistors" and can just use one of them, so you don't need to order at all. Current market price for these transistors is around 2ct/piece in small quantities, so the offer you cited has some markup over the pure component value, but the final price including national shipping and handling seems fair. And that's why people actually building stuff using these transistors often start at getting 100 of them at once, and factories buy them in reels of 2500 transistors. Furthermore, let's check the size: Those transistors exist in the "big" SOT-23 package and the "small" SOT-323 package. I tried to measure the dimensions of G14 by pixel counting and got inconclusive results. SOT-23 is around 2.9mm wide, with a pin distance (center-to-center) at the right side of 1.9mm. SOT-323 on the other hand is around 2.0mm wide with a pin distance of 1.3mm. If the transistor is SOT-23, the BC848B will fit. If the transistor is SOT-323, the BC848W would be the correct size.
