First post, by stu_e_hughes
Hi everyone,
I have a working board -the PCChips/Hsin Tech M537DMA33 as linked here.
https://theretroweb.com/motherboards/s/pcchips-m537dma33
Probem is, i'm trying to connect a mouse to the PS/2 port. I've made my own connector using a PS/2 extension cable with seperate wires for clock, data, +5v and ground. But i've no idea onto which connectors I need to attach them onto this pinout on the motherboard. (photo attached). As you can see it has 7 pins...
Any help would be greatly appreciated.
