First post, by mmx_91
- Member
Hi all,
I'm thinking about building a very small form factor system, as I've encountered that, among all the retro stuff I posses: most of the times I want to play something retro, I end up using a small board that fits really well my needs, connected to living room flat TV with all sort of modern amenities 😀
This board comes from an Intel Dot Station (known here in Spain as Pakito), upgraded to Pentium III 1Ghz 100FSB, 1xDIMM 256MB SDRAM and Geforce 6200 PCI.
It allows me to get HD resolutions in desktop, and very sharp 640x480, 800x600 or 1024x768 for games using DVI to HDMI. Using SD to IDE as well as wireless keyboard&mouse is very handy to just start playing something with no more headache 😀
So my idea is to DIY a very small wooden case that matches the furniture and contains only the board, GPU, SDtoIDE adapter and a couple of fans.
Given this, I have doubts on which will be the best PSU option for this build:
- The one I use now which is a TFX PSU: plenty of power, but it will oblige the case to be bigger and heavier and I'd want to avoid it
- Second option would be something like Pico PSU:
https://www.mini-itx.com/store/?c=10
This would be ideal in case I can feed it with a hidden external laptop power brick, for example, but I'm worried about current they can deliver.
As many stated here, they are quite weak in delivering 5Volt rail which is the one these old systems use the most. Most of these models I've read about deliver only 6 to 8 Amps in 5V rail, which I think it's quite low, isn't it?
Only the processor has a TDP of about 30W, which added to GPU consumption and peripherals may be quite tight or not sufficient at all, I'm afraid 🙁
From the board datasheet (MO810e), it says that a 500Mhz PIII will pull more than 2 Amps from 5V rail and 2 more amps reserved for PCI slot. As long as my CPU is more power hungry, I'm afraid a PicoPSU may work towards the limit:
What do you guys think? Does anyone have experience with similar systems and SFF PSUs?
Thanks a lot!
