Glidos games support ?!
First post, by Guest
for games like Screamer rallye and a few more oldies ?
is the wrapper supposed to work out of the box for them ?
Reply 1 of 5, by Glidos
Not quite "out of the box". You need to edit C:\Progam Files\Glidos\glidos.ini, make a new section mostly a copy of the Screamer 2 section, but with the path changed.
Reply 2 of 5, by Guest
ok i ll buy it then i guess.....
i 'll need to ask you about a few more games...
all those old games - some of them were SO PLAYABLE....
oh one more that springs to mind.....
IGNITION ??! what about that one !?
Reply 3 of 5, by Glidos
Ah! Hang on! Don't buy it for games you have not tried out. Even the listed games give problems on some systems. The unlocked copy is perfectly adequate for testing.
Reply 4 of 5, by Guest
man if you say it works on screamer rally. i 'd buy it for that alone, 10 bucks is very reasonable - for what you offer, plus as i m about to get a pci-e system - i cannot think of any possible way to get my v2 sli in there....
you 're right though - i ll toy around with the games first.
i m not getting paid till the 25th anyway. 🤣
thanks for the speedy replies.
Reply 5 of 5, by Glidos
Oops! Didn't mean to imply that. The instructions I gave were for trying it out. May well work if it uses the same game engine that S2 uses, but there are all sorts of ways it could fail.
