Intel DX4 100 WB or not?
First post, by Jackhead
Hi,
i switched from a A5x86 X5 to a Intel DX4 100.
The X5 is to fast for my usecase.
I struggle a bit setup the CPU.
First my cpu is the SK096. On wiki for the Intel DX4 is written the SK096 has WB . But on my chip is nothing written from WB..
Also the CPU Codename is P24C
On my mainboard manual the jumper setup is for a P24D and for a P24CT.
What should i use ?
regards
Chris
Dos 6.22: Asus VL/I-486SV2GX4 Rev 2.0 1Mb L2 - A5x86 X5 P75 - 64MB - AHA-2842A VLB - ET4000W32P VLB - CT2230 - GUS ACE - MPU-401AT with YucatanFX
Win98SE: Asus P5K-WS - E8600 @ 4,5GHz - Strange God Voodoo 5 6000 PCI-X - 2GB DDR2 1066 - Audigy 2 ZS
Reply 1 of 27, by PD2JK
What about this wikipedia info:
The original write-through versions of the chip are marked with a laser-embossed “&E,” while the write-back-enabled versions are marked “&EW.”
Any Speedsys cache score differences with both jumper positions?
i386 16 ⇒ i486 DX4 100 ⇒ Pentium MMX 200 ⇒ Athlon Pluto 700 ⇒ AthlonXP 1700+ ⇒ Opteron 165 ⇒ Dual Opteron 856
Reply 2 of 27, by Jackhead
hard to see but i cant see &E or &EW or anything with WB lasered on the chip.
But SK096 should be wb as wiki say..
The attachment IMG_7230.jpeg is no longer available
Did not bench for now i just setup jumpers for P24D with WB and look if it boots, and yes it boots fine with bios set to WB.
Reply 3 of 27, by PD2JK
Then I think you're alright. (assumption, benchmark for numbers 😉 )
The P24D jumper setting takes care of the WB setting, and the internal clock multiplier of the DX4 does the rest.
Reply 4 of 27, by kixs
If it's true SK096 then it also has 16KB of L1 - check with Speedsys or checkcpu
Visit my AmiBay items for sale (updated: 2025-10-29). I also take requests 😉
Reply 5 of 27, by Jackhead
Ok will do the benchs later.
I also set the multi to 2 to get 66MHz. I think its nice to have the option switch between 100 and 66 setup . The idea is running on 66Mhz with attached turbo button for switching it down for speed sensetive games. With no L1/L2 i should reach a 386/33 region hopefully.
And adding a extra switch to the Multi header for switching to 100Mhz for the later stuff.
My X5 was to fast even with no L1/L2 and base clock 133 for games like Ultima7..
Reply 6 of 27, by Disruptor
Jackhead wrote on 2024-08-26, 09:05:
hard to see but i cant see &E or &EW or anything with WB lasered on the chip. But SK096 should be wb as wiki say.. […]
&EW is easy to see on your picture.
So it is a write back model.
Reply 7 of 27, by Jackhead
Looks good:
The attachment IMG_7233.jpeg is no longer available
How do i get out of cpu protection mode again? For benching the cache.
Reply 8 of 27, by Disruptor
Run it under pure DOS.
No EMM386.
(Probably boot with F8)
Perhaps you try ctcm from heise Magazin too.
https://ftp.heise.de/ct/ctsi/ctcm17a.zip
Reply 10 of 27, by Jackhead
Here the result, normal for the DX4 ?
The attachment IMG_7235.jpeg is no longer available
and here with slowest hardware settings. Really slow 😀 I think that could be 386/33 range.
The attachment IMG_7236.jpeg is no longer available
Reply 11 of 27, by kixs
386DX-40 has score around 8. So this is around 386DX-20. Too slow 😉
Reply 12 of 27, by Disruptor
Jackhead wrote on 2024-08-26, 16:50:
I don't have had any Intel DX4 yet.
But your speedsys cache/memory chart looks quite okay for 33 MHz FSB.
Can you test your system for stability?
(Play different games with sound more than 15 minutes, like Raptor, Duke3D, Doom - try to install Windows NT 4.o)
Reply 13 of 27, by Jackhead
Ok did some testing and with the jumper settings "P24D" Whatever D or CT difference is. I know it has to do something with the codename. But i cant find information about it.
Anyway with P24D i had strange issues with crashes loading software. System boots fine even benchmark np.
So i crosstest anything again. Also switched the I/O controller, nothing.
Now i jumped to "P24CT" I found intel DX4 is codename P24C but what the is than the T again?...
It works now.
I have also a sheet where complete different jumper setup:
The attachment Asus486Board CPU.png is no longer available
Oh another Intel DX4 "ODP" ?? Come on... 😀
The Asus Manual is pointing on REV 1.x i think, and the sheet is Rev 2.0 2.1.
This is really creazy stuff.
Reply 14 of 27, by Jackhead
Here the Bench with P24CT jumped
The attachment IMG_7240.jpeg is no longer available
You can notice that the CPU name has changed, and the L1 cache is slower. 1point more on cpu bench.
L1 is in WT mode, but jumped to WB and bios is also set to WB.
Wonder what jumper is needed to get WB. As i say JP21 is jumped 3-4.
The attachment Screenshot 2024-08-28 194600.png is no longer available
Reply 15 of 27, by TheMobRules
For an Intel DX4-100 with L1 WB you need to follow the settings labeled i486DX4-&EW in the jumper sheet above. It should be the same settings as an AMD 5x86 but without setting the 2x-4x multiplier jumper JP20. Don't forget to also set the proper Hardware Trap jumpers JP5 and JP6 to 1-2.
The jumper that toggles L1 between WT and WB is JP21 (off for WB, set to 2-3 for WT).
As for the 486 CPU codenames:
  • P4: 486DX
  • P23: 486SX
  • P24: 486DX2
  • P24C: 486DX4 (same codename for both L1 WT and WB versions)
  • P24D: 486DX2-WB
  • P24T: Pentium Overdrive
The suffix "-S" indicates an SL-enhanced CPU (power-saving capabilities).
As for the P24CT, I think this was supposed to be a 3.3V Pentium Overdrive that was planned but never released, so it may have ended up in the manual because it was written before Intel decided not to go forward with that CPU.
Reply 16 of 27, by Jackhead
ah great Info thanks!
JP5 6 are 1-2 short
here my cpu jumper:
The attachment IMG_7243.jpeg is no longer available
Ends up in no boot.
Reply 17 of 27, by CoffeeOne
Jackhead wrote on 2024-08-28, 19:15:
ah great Info thanks! […]
JP5 6 are 1-2 short
here my cpu jumper:
Ends up in no boot.
Hmm.
You had before the Am5x86 in L1 WB mode. Is it correct?
Then just use the exact same setting for the Intel DX4-WB.
The setting in Bios for L1 WB or WT does not matter at all, you need correct jumper settings to run L1 in WB mode (for Intel or AMD 5x86 CPUs).
EDIT:
Your jumper setting is bad. Hopefully you did not fry the CPU, because you forced 5 volts by disabling voltage auto detection. Always set a jumper to JP16 1-2.
Reply 18 of 27, by Jackhead
Thanks for the info. I think my CPU is still alive..
I found out that with that settings the system only boot when i disable L1 or l2 in bios.? Both enable dont work.
And yes i have jp16 now 1-2 shorted 😀
And yes i run the x5 with WB L1/2 . I also have that bios with L2 WB fix installed.
Reply 19 of 27, by Jackhead
Another try, so i removed my MB and double check anything under the scope. Anything looks good.
So i installed only the VGA to test system starts. But again with L1 and L2 no boot. When i turn off L1 or L2 system boot.
Atm i think my board are maybe die..
Would be great if anyone with the board and a DX4 can tell me my jumper are correct.
The attachment IMG_7256.jpeg is no longer available
The attachment IMG_7255.jpeg is no longer available
The attachment IMG_7254.jpeg is no longer available
