First post, by sdz
There seems to be very little information about this card on the internet, so if anyone is interested in a specific test or benchmark, let me know.
The attachment S1.jpg is no longer available
The attachment S2.jpg is no longer available
The attachment S3.jpg is no longer available
The attachment S4.jpg is no longer available
The attachment S5.jpg is no longer available
Reply 1 of 11, by sdz
The attachment S6.jpg is no longer available
I have no clue what the DIP switch on the bottom of the board does, I'll try to mess with it later.
The attachment S1.png is no longer available
The attachment S2.png is no longer available
The attachment S3.png is no longer available
The attachment S4.png is no longer available
Reply 2 of 11, by The Serpent Rider
Proper 16-bit color support?
Reply 3 of 11, by Nemo1985
Impressing, where did you find it? A Pci express s3 card WOW
Reply 4 of 11, by SPBHM
Nemo1985 wrote on 2024-08-26, 17:59:
around 2007-2008 S3 had the Chrome line, 400 and 500 series which was a DX10 GPU more or less competing against the 8400GS
Reply 5 of 11, by Nemo1985
SPBHM wrote on 2024-08-26, 18:10:
Thank you I didn't know. I suppose it's not easy to find nowadays.
Reply 6 of 11, by Masterchief79
17500 points in 3DM01 is not bad. That's about the same performance as a 5800 Ultra or a Radeon 9700. Any idea what a competitor from the same time scores? I guess I have an 8400GS or something similar laying around, if you don't.
Reply 7 of 11, by Putas
I would like to see results from any games relevant at the time that haven't been tested yet.
Reply 8 of 11, by sdz
The Serpent Rider wrote on 2024-08-26, 14:18:
Can you be a bit more specific?
I found it on ebay.
Masterchief79 wrote on 2024-08-26, 20:01:
I don't have any cards from that generation to compare it with.
Putas wrote on 2024-08-27, 07:50:
Any suggestions?
Reply 9 of 11, by The Serpent Rider
16-bit dithering.
Reply 10 of 11, by bakemono
For 3Dmark01 that's pretty close to a GeForce 210. I remember getting 18 thousand and something on the GF210, and 24 thousand on a Radeon HD 4550. It's interesting that the S3 card has GDDR2 chips on it. Maybe they were soaking up the remaining stock after ATI and nVidia had already moved on to GDDR3.
edit: on second thought, I'm not sure if that is 'real' GDDR2, since the data sheet shows the same voltage as normal DDR2. They call it "gDDR2" with lowercase 'g'...
GBAJAM 2024 submission on itch: https://90soft90.itch.io/wreckage
Reply 11 of 11, by Putas
sdz wrote on 2024-08-27, 19:51:
Any suggestions?
What was big at the time? Some Stalker, Fear, Civilization, Bioshock, Batman, Burnout Paradise, Street Fighter IV, Warhammer, sports...
