First post, by Blackfire74
Hi there,
Specs first:
Using DOSBox not Dosbox-x
Everything works fine, got config working for all games I want
Just bought a joystick Quickshot Warrior 5, 2axis, 2 buttons, Autofire switch, 2 calibration wheels, autocenter/loose switches
Tested on controller tester where all movements and buttons are registerd properly with proper sensitivity
All set in DOSBox mapper
ISSUE:
got joystick for Slipstream5000 mostly and mainly. The thing is that buttons presses are registered randomly, once they work once not. Sometimes button works few times in a row, once I can press it a LOT of times with no luck.
I tried different cycles, nothing. Maybe I didn't put the right value. There are many thousands of them to try!
I also tried few joystick configuration options, also nothing.
Maybe someone had the same issue and solved it?
