First post, by x73rmin8r
- Newbie
I've got one of those problems that feels like a punch to the gut.
Got a Asus TX97-X motherboard, installed it with a StarTech AP-350x power supply (not new), replaced the cmos battery, and started it multiple times and got to the BIOS successfully. After installing the CD drive and cf card reader I turned it on again and it went to a blank screen in the middle of it scanning IDE masters and slaves.
Now it powers the fans on immediately without me actually turning it on whenever the PSU switch is turned on and never triggers the monitor to come out of sleep mode. If I remove the cmos battery it waits for me to turn it on, but then after I turn it on once it behaves the same way every time I give it power.
I read that if you plug in ide cables backwards it can cause this, but the floppy drive was working correctly and the CD drive and cf card reader are keyed so you can't plug them in backwards.
Is this thing just ruined now? Is the PSU possibly dangerous now to where I shouldn't risk it on another motherboard?
