First post, by curvedline
ECHO 1. disable music
ECHO 2. enable music
choice /C:abcdefghijklmnoprstuvwxyz1234567890q /N "Q to quit or any other key to play"
IF ErrorLevel 36 GOTO :END
IF ErrorLevel 27 GOTO :enable_music
IF ErrorLevel 26 GOTO :disable_music
GOTO :CONTINUE
:enable_music
res-adl.EXE -o
GOTO :CONTINUE
:disable_music
res-gen.EXE -o
GOTO :CONTINUE
:CONTINUE
play.exe
:END
my made res-adl.EXE and res-gen.EXE are compressed DOSZIP files but are needed to replace a configuration to control music.
sierra DOS games bypass the music/midi dosbox virtual devices because damn sierra games are known for "no digital sound effects" and no option for "no music" and its in-game music control bar always STARTS with 100% and it doesnt save a music setting upon quitting . unlike westwood's kyrandia, when sierra game's in-game music bar is 0%, this means background music is turned off and midi sound effects are ALSO turned off.
because pkzipDOS.exe compresses and i have to replace it
i need some kind of DOS command or pkzipDOS.exe kind of software that MUST NOT compress files and combine all files into a single EXE file.
this single output.exe also needs to have this switch
output.exe -overwrite
if in an example of win32 ZIP version , the command line would be like this "PKZIPC.EXE -SFX -LEV=0 output"
PKZIPC.EXE -SFX -LEV=0 ;no compression and fast and i need this
PKZIPC.EXE -SFX -LEV=5 ; compresses and i dont need this
Reply 1 of 11, by wbahnassi
Can't you just Qbasic it and make it an exe?
TurboXT 12MHz, EGA, MFM HDD
Intel 386 DX-33, Speedstar 24X, SB 1.5, 3x FDD
Intel 486 DX2-66, CL5428 VLB, SBPro 2, 2x CD
IBM BlueLightning 100MHz, CL5428, SB16, 4x CD
Intel Pentium 90, Matrox Millenium 2, SB16, 4x CD
HP Z400, Xeon 3.46GHz, YMF-744, RTX2060
Reply 2 of 11, by Grzyb
I think every archiver has an option to store files without compression...
InfoZIP:
zip -0 archivename filename
RAR:
rar a -m0 archivename filename
In 2003, I voted in favour of joining the European Union. However, due to later developments - especially the restrictions on cash usage - I have withdrawn my support. DOWN WITH THE EU!
Reply 3 of 11, by curvedline
thanks very much
i missed the -e line end
Usage: PKZIP [options] zipfile [@list] [files...]
-e[x,n,f,s,0] use [eXtra|Normal (default)|Fast|Super fast|NO compression]
pkzipdos -e0 !ttt1.zip RESOURCE.CFG
zip2exe !ttt1.zip
Reply 4 of 11, by Grzyb
But if you don't need compression, you don't need an archiver.
You can simply keep several versions of the config file with different names: CONFIG1.CFG, CONFIG2.CFG...
and copy the appropriate vesion over:
copy CONFIG1.CFG RESOURCE.CFG
Reply 5 of 11, by curvedline
thanks for clearing my head, i got this sort of things going on with windows games, i collect a bunch of savedgames and settings in 0% compressed format. my brain got stuck there for long, long names gave comforts, so my habits got stuck there deeper.
!RESOURCE.CFG - adl ,patchdir implemented.EXE --- became DOS version res-adl.EXE
!RESOURCE.CFG - genmidi, patchdir implemented.EXE --- - became DOS version res-gen.EXE
!AS2 - Conscription - saved game 01.exe
!AoW1 - cult lizard undead 1 - 3dead 2water 2earth.EXE (collected 300 savedgame files)
!AoW1 - keeper dwarf highmen 2 - 3life 2water 2earth.exe
!JA2 - savedgame - sam sites 2.EXE (collected 500 savedgame files)
!RA2 - Mission - Yuri - Yuri's Training ground 1.exe (collected 50 MODS and maybe 50 savedgame files)
i will use your method at least once somewhere that is gonna tell me this kind of method also exists
but i still need to do this for replacements between many savedgames
Reply 6 of 11, by myne
Grzyb wrote on 2024-08-28, 05:02:
But if you don't need compression, you don't need an archiver. You can simply keep several versions of the config file with diff […]
Yeah.
If exist config.cfg del config.cfg
Copy config1.cfg config.cfg
Goto continue
Done.
Add as many files as necessary to achieve this.
I built:
Reply 7 of 11, by Grzyb
myne wrote on 2024-08-28, 10:43:
No need to DEL, the COPY command overwrites it anyway.
Reply 8 of 11, by myne
Hmm
Command and cmd are so different I can't honestly say you're right or wrong, but usually things complain when you overwrite existing files, and you have to at least /y it to overwrite.
I built:
Reply 9 of 11, by Grzyb
In early DOS versions, COPY always overwrites files without asking.
In late DOS versions, it depends:
- when invoked interactively, COPY asks whether to overwrite
- when invoked from a .BAT, COPY overwrites without asking
Reply 10 of 11, by BloodyCactus
set COPYCMD=/y
or just "copy /y" to suppress confirmation
Reply 11 of 11, by curvedline
thanks for these two advice
after few days, i dropped the use of compressed file format for replacing settings
copy command overwrites and is unnoticeabely fast and smooth
