First post, by Kahenraz
I bought a bunch of these Chinese knockoff ESS Solo-1s that seemed to work fine in several motherboards but can throw a fit in others. For example, I'm trying to slip it into a thin client with a 45 degree angled connector. I thought that it might be small enough to tuck away inside. However, the issue I'm having is that the sound card doesn't work at all in this system. It is detected by the drivers but only emits electrical hums instead of any audible sound.
Why might it be failing to work in my thin client? I tested that both 3.3V and 5V exist on the PCI slot. What else could be missing that is needed on the PCB? I'm curious if it's something that I can retrofit onto it to salvage this project.
I have an ESS Allegro on a similar cut down PCB with the same problem, so it's not limited to just the Solo-1.
The attachment 20240827_232253.jpg is no longer available
Reply 1 of 4, by zyga64
Kahenraz wrote on 2024-08-28, 03:27:
I bought a bunch of these Chinese knockoff ESS Solo-1s that seemed to work fine in several motherboards but can throw a fit in o […]
-12V missing ?
PCI Riser Card capacitors - required on all thin clients?
Scamp: 286@20 /4M /CL-GD5422 /CMI8330
Aries: 486DX33 /16M /TGUI9440 /GUS+ALS100+MT32PI
Triton: K6-2@400 /64M /MGA-2064W+3dfx /ES1370
Seattle: P!!!750 /256M /MX440 /Vibra16s+SBLive!
Panther Point: 3470s /8G /GTX750Ti /HDA
Reply 2 of 4, by Kahenraz
Yes, that seems to be the issue. I confirmed that there is no -12V on the PCI slot. I wonder why the larger version does not have this problem.
Reply 3 of 4, by jtchip
Kahenraz wrote on 2024-08-28, 06:03:
On the smaller card, there is an op-amp at U4, probably an LM386 or compatible. Pin 4 is the negative voltage input, which is likely connected to pin B1 (component-side, nearest the bracket) which is -12V. The ES1938 and ES1946 datasheets (on page 19 and 22, respectively) have this to say about AOUT_L/R:
...analog outputs AOUT_L and AOUT_R should be AC-coupled to an amplifier, volume control potentiometer, or line-level outputs.
So perhaps you could bypass the op-amp and recreate the same components from the TTSOLO1-S on the smaller card.
The larger version (looks like a Terratec Solo-1) doesn't appear to have an op-amp. There is an optional power-amp that is not fitted, the traces at JP1 for pins 3, 4 appear to go to the filter caps C45, C46? Presumably from there it goes to the AOUT_L/R on the ES1938S. Also trace pins 1, 2 and see what components they go through.
Reply 4 of 4, by holdencars11
This is the card I have been looking for on AliExpress but they keep on sending Maestro-2SC hahh
Ryzen5 1600AF/ASRock B450Mac/16Gb/HD7750
i7 2600K/P67A-C43/16GB/GTX560
i7 960/MSI X58 Pro/8GB/8800GTS
Athlon II x4 620/GA-M56-S3/8GB/8800GTS
Duron 1300/A7S333/512MB/MX440
6x86MX PR200/PC Chips M571/64MB/ET6000
NEC PowerMate1 268 10MHz
And another 40 rigs.
