First post, by Kahenraz
There are already lots of these available online, but I have a particular use case that requires that the PCI slot be offset to the side.
I am trying to squeeze a PCI sound card into a tiny thin client where the official expansion module is unobtainable. I plan to desolder the stereo audio connector and route my own to the internal PCI sound card, making the installation seamless. I found some cutdown ESS Solo-1s that fit perfectly, but for some reason they refuse to work in this system. However, all of my standard-size Solo-1s work fine but don't fit! Even if I were to remove the ports, the vertical height isn't enough to clear the Parallel port. The whole card will have to be offset for it to fit.
How can I make a PCB like these ubiquitous right angle risers with a modification where the slot is offset to the left? I have soldering skills to attach the PCI slot but I don't know anything about designing PCBs.
Brownie points for an additional design where the card ends up upside-down. I'm curious if I can squeeze a wavetable card in there too. There isn't enough room in the slim case for one if the card is oriented right side up
The attachment 20240828_012345.jpg is no longer available
The attachment 20240828_011209.jpg is no longer available
The attachment 20240828_011432.jpg is no longer available
The attachment 20240828_011935.jpg is no longer available
The attachment 20240828_012044.jpg is no longer available
Reply 1 of 7, by Kahenraz
It seems that the issue with the smaller PCB failing to work has to do with the lack of -12V. I don't understand why the larger card doesn't have this problem.
Re: Why isn't this cut down ESS Solo-1 working as expected?
Reply 2 of 7, by zyga64
Larger card doesn't have op-amps soldered (empty places). Smaller one has 8 pin chip soldered - which is probably op-amp needed symmetric (+ and -) power supply.
Scamp: 286@20 /4M /CL-GD5422 /CMI8330
Aries: 486DX33 /16M /TGUI9440 /GUS+ALS100+MT32PI
Triton: K6-2@400 /64M /MGA-2064W+3dfx /YMF718
Seattle: P!!!750 /256M /MX440 /Vibra16s+SBLive!
Panther Point: 3470s /8G /GTX750Ti /HDA
Reply 3 of 7, by Kahenraz
Can I bypass the op-amp for line level output? I don't need the output amplified to my amplified speakers.
I've attached a picture with a close-up of the chip.
The attachment 20240828_023031.jpg is no longer available
Reply 5 of 7, by zyga64
Kahenraz wrote on 2024-08-28, 06:29:
Well I'm not an expert, but I think that op-amp is here to drive headphones. It's probably to weak to drive passive speakers.
However, after quick look on datasheets of both Solo-1 (ES1938) and Solo-1e (ES1946) it seems that main difference is IC supply voltage (+5V vs +3.3V), and their pinout looks identical.
So you could trace the paths on the board (of your larger card without an amplifier) from pins 50 and 51 of the ESS chip to the audio output jack.
Quote from datasheet:
AOUT_L, AOUT_R  |   50, 51  |  O  |  Line-level stereo outputs, left and right. These pins can drive a 5k Ω AC load.
And based on that, recreate the same situation on the smaller card...
Reply 6 of 7, by lti
A 4558 won't drive headphones either (not enough output current). It's just configured as an inverter (all resistors are the same value, so it doesn't amplify). I don't know what they were thinking with that circuit (maybe to protect the Solo 1 chip from a shorted output).
This is such a simple circuit that it will be easy to bypass, but it will require either removing the chip or cutting traces. The line output connects to C22 and C24, which are probably both severely undersized (meaning that there will be no bass unless you replace them). The output pins on the chip will have a DC offset of about 2.5V, so you will need to keep a series cap of around 10µF. The other option is to use an isolated DC-DC converter to make -12V from +12V or +5V, and then you could use any card you want.
Re: Low volume out of Cobra AW744L II card
You don't have to use a dual-output model like that. Since they're isolated, you can use a single-output version and connect +Vout to ground to get a negative voltage.
I remember seeing flexible PCI risers using ribbon cables many years ago. Those might be your best option if you can still find them (and if the excess cable length can fit inside your thin client).
Reply 7 of 7, by Kahenraz
I ordered some little DC-DC boards from AliExpress to try out, since that seemed like the easiest option.
Which pins should I tap into on the PCI slot to add the -12V? And is there someplace I can probe between the slot and the card to validate that it's connected properly before plugging it into the motherboard?
I have soldering skills but no actual electrical engineering knowledge.
