First post, by mombarak
- Member
Hi everyone,
I have a P90 with a Socket 7 mainboard and a Soundblaster 16S Vibra and a Matrox Milennium 2 MB PCI card. Instead of a classic HDD, i added a DOM flash disk which can be directly plugged on the IDE port. This works great. On my new setup I noticed that the computer makes these high pitches whine sounds for some seconds when it "reads" something. I say this because I think this is what it does while it happens. It is always reproducible when it loads the HIMEM.SYS during the MS DOS 6.22 boot in DOS. Other cases seem to be when I am using scandisk or do something on the disk or sometimes in a game.
Can this be the RAM or do I have to suspect the DOM module? I tried multiple and it happens on all. Also I have placed the ISA soundcard on the lowest slot and the PCI graphics card on the lowest slot on the board to get it far away from RAM and CPU.
Has anyone experienced the same? My next steps would be to try to swap RAM and to try a classic hard disk.
