First post, by bretwashere
Hello,
I finally received an extremely rare system in private collections, a HP 3000 Micro GX from the region of South Africa (I live in the United States). More information of that system can be read here at the HP Museum website: http://www.hpmuseum.net/display_item.php?hw=656
Here are some photos I shot post unboxing, in amazing shape except for some tape residue:
And with the system turned on...
Here is my current issue. I belelive one of the EDSI Hard Drives had a head crash in shipping, or the melted rubber caused the head to adhere to the platter from the gravity of how the minicomputer was shipped, and the age of the full height drives. Here is the console output when I attempt to boot the machine, followed by a knock from the hard disk then a spin down:
mainset microcode is NOT loadedAuto warmstart disabledWCS Boot failure:last system stop code (hex)=0000 Can't read sector zero from CS-80 deviceAR - Re-attempt Auto Restart, PA[nel] - Enter soft-panel,1-NORMALCOL[dstart], REL[oad],H for help->disCOO[lstart], RUN,DI[sc] - Start from Disc, SP[eed],WCS Boot failure:DU[mp] [chan, dev], ST[art] [chan, dev[,{P[erm] ]], Can'tDW - disable auto warmstart, C[hange]}EW - enable auto warmstart, TA[pe] - Load from Tape,1-NORMALL[oad] [chan, dev[,{P[erm] ]], TE[st],H for help->hC[hange]} UPD[ate],NEW[system], WAR[mstart],1-NORMALH for help->1-NORMALH for help->colWCS Boot failure:Can't read sector zero from CS-80 device1-NORMALH for help->cooWCS Boot failure:Can't read sector zero from CS-80 device1-NORMALH for help->
This leads to my question: When I removed the hard drives, they look like MFM/RLL interfaced ST506 drives. I did some researching, and it appears that some savvy folks in the day did piggy back on MFM/RLL interfaces and hard drives, however, the controller was EDSI or SCSI. I am not quite sure how I should go about replacing it. Yes, the pinout on the hard drive does appear to be MFM, but do you think it could be as easy as plugging in a like drive into the controller and the controller will just do all the conversion? I have some pictures to show the faulty hard drive, the pinout and the controller for this "EDSI" hard drive:
The details on the top are the following:
Can anyone please point me in the right direction on where I should go next?
Sources: EDSI/SCSI using MFM/RLL drives with different controller: https://en.wikipedia.org/wiki/ST506/ST ... velopments (https://storage.microsemi.com/en-us/support/_ … /acb/acb-4000a/)
