First post, by p.kapica027
I'm on pure MS-DOS 7.10 (the VER command reports "Windows 98 [Version 4.10.2222]") and wondering about the possibility of changing that output to read "MS-DOS version 7.10" which is similar to earlier versions of DOS.
For some strange reason, the VI editor from Watcom 11 never fails to garble VER output after running under MS-DOS 7.10, not with other versions having a shorter version string (i.e. "MS-DOS version 5.00"). For the record, I'm really not that into invoking VER every time I close the editor, but it's a mess when running scripts that try to parse this output. My only solution is to reboot the computer if I want clean VER output. In my case, that's a VMware virtual machine.
Any way of accomplishing this?
Reply 1 of 23, by Cyberdyne
Find and HEX edit it in command.com.
Reply 2 of 23, by AlaricD
p.kapica027 wrote on 2024-08-30, 18:01:
There is, and you may also run into all your MS-DOS externals reporting "Incorrect DOS Version".
Reply 3 of 23, by Grzyb
AlaricD wrote on 2024-08-30, 21:15:
Really?
Don't they use INT 21h to obtain DOS version, rather than invoking the VER command?
Nie rzucim ziemi, skąd nasz root!
Reply 4 of 23, by p.kapica027
Cyberdyne wrote on 2024-08-30, 20:13:
Thanks for the suggestion. Unfortunately this doesn't seem to work with the COMMAND.COM included with Win98 DOS. I used a binary editor to replace all strings matching "Windows 98 [Version %1]" with "MS-DOS Version 7.10 " (padded with spaces to match the original string length), but that darned VER command still responds with "Windows 98 [Version 4.10.2222]". Seems like 7.x version of COMMAND.COM might be getting this information from elsewhere.
Reply 5 of 23, by p.kapica027
I'll look at this from another angle, then. Maybe I should've been specific and asked why does Watcom VI cause problems with the VER command in MS-DOS 7.10? After starting and then exiting the VI editor, executing VER gets me "Windows 98 [Version " followed by garbled data about T_FIND, some numbers and some extended ASCII characters. I have no idea what's behind it and it's mucking up a script I use. Going to an older DOS version isn't a good option since MS-DOS 7 is LFN friendly, and I like to preserve the case of filenames when sharing with Windows and Linux.
Reply 6 of 23, by Ringding
This actually works. I tried it. The string "Windows 98 [Version %1]" is a pascal string with the length byte in front, while "4.10.2222" is zero-terminated.
Reply 7 of 23, by wbahnassi
I did it once for jiggles and it was straightforward. I just wanted to replace all strings reporting Windows 98 to be MS DOS but keep the version 7..etc. There were quite a handful of such strings that I replaced carefully while maintaining spacing and character count. Then just save the new file and done. I can't see how this "can't work".
Turbo XT 12MHz, 8-bit VGA, Dual 360K drives
Intel 386 DX-33, Speedstar 24X, SB 1.5, 1x CD
Intel 486 DX2-66, CL5428 VLB, SBPro 2, 2x CD
Intel Pentium 90, Matrox Millenium 2, SB16, 4x CD
HP Z400, Xeon 3.46GHz, YMF-744, Voodoo3, RTX2080Ti
Reply 8 of 23, by Ringding
But you don’t even need to maintain the length.
Reply 9 of 23, by Grzyb
There was that "China DOS Union" thing identifying itself as "MS-DOS 7.10"...
Reply 10 of 23, by Cyberdyne
Grzyb wrote on 2024-08-31, 07:16:
Allso just a simple HEX edited thing.
Reply 11 of 23, by myne
Can't you just use setver in a bat?
I built:
Reply 12 of 23, by Grzyb
myne wrote on 2024-08-31, 09:01:
SETVER doesn't affect the VER command.
VER command in MS-DOS 7.x doesn't display the DOS version - instead it pretends it's Windows, not DOS 🤣
Reply 13 of 23, by myne
https://www.computerhope.com/setverhl.htm
I built:
Reply 14 of 23, by p.kapica027
Ringding wrote on 2024-08-31, 04:47:
Okay, I'm going to give it another shot next week. Thanks for the info about mixing C and traditional Pascal strings—I had modified command.com with a text editor in binary mode where a proper hex editor should've been used to expose each byte numerically.
Reply 15 of 23, by p.kapica027
myne wrote on 2024-08-31, 11:51:
That page describes the SETVER program, which maintains a database of individual executable names and for each an associated 'fake' DOS version number that gets reported internally at run time. SETVER does not in any way affect the output of the command shell's internal VER command, which is what gets garbled after running a certain program on my system, in turn affecting a batch file (unless it's rebooted first). The main thing is, VER will by default always display the actual DOS version you're running whether SETVER.EXE is loaded or not. That's why poking around that COMMAND.COM binary is the only way to modify the string displayed by VER.
Reply 16 of 23, by myne
Tried setting it for vi?
I built:
Reply 17 of 23, by p.kapica027
myne wrote on 2024-08-31, 13:21:
Yes. I've added the vi executable to setver, associating it with version 5.00 and then 6.20. Neither worked, but it was definitely worth a try.
Reply 18 of 23, by jakethompson1
The OS/2 museum guy tracked down a bug in that same variant of vi a while back: http://www.os2museum.com/wp/tracking-down-a-bug/
Maybe if you can give instructions to reproduce this he'd be convinced to dig into it if he is already familiar with the code.
Reply 19 of 23, by p.kapica027
jakethompson1 wrote on 2024-08-31, 15:52:
What's happening, in my case, is that exiting vi causes VER to print "Windows 98 [Version " followed by either bits of its config file if vi was started with an empty buffer, or bits of the file that was just loaded into vi if it was an existing file.
I'm now searching for a better vi. This one definitely has more serious issues than the one I've encountered and I hear the Open Watcom v2 codebase is messy, so I don't expect any official fixes soon.
