First post, by x73rmin8r
- Newbie
I just got an Akai SG01K, got it hooked up to a working PC/MIDI system, but I can't get it to receive any MIDI signals through the MIDI IN port. Other midi boxes play music correctly when I swap the midi cable between them, and the Akai will play its internal demo tracks if I select them, but it doesn't play anything through the MIDI cable. There's a small indicator light that blinks when it's supposed to be processing MIDI signals that blinks when it's playing the demos, but never any other time.
Does anybody who has one of these know if it has some special mode it needs to be in to accept signals? I've tried switching between Single and Multi Channel mode. Is the input probably just broken? All the other MIDI modules I've used just start playing as soon as there's an input signal, interrupting whatever menu you were in.
Had a look at the solder connections and nothing looked messed up.
