First post, by psaez
Hi
I run it under windows 95 and using a sound blaster 128 PCI.
I entered setup and tried with general midi with no sound. Then tried with sound blaster awe 32, sound blaster 16 and other sound card configurations and I got music working but is a very bad music. Not the original one we remeber.
How can we improve it?
Reply 1 of 9, by leileilol
You can't. Sound Blaster AudioPCI cards don't do OPL and will be approximate emulation at best. DOS is dead, bleep bloops are lower priority than environmental audio, HRTF, full duplex, and clean MP3s. Those were the goals of sound cards at that point.
If you're running Win95, then your board's probably old enough to have an ISA slot for an OPL'd sound card...
long live PCem
Reply 2 of 9, by psaez
leileilol wrote on 2024-09-02, 19:29:
If you search in youtube sound blaster 128 pci doom music you will see that the music should sound better
Are you sure? And the only way to get the real music is to use an older ISA card?
Reply 4 of 9, by PD2JK
Review: Sound Blaster PCI 128 (CT4810)
Scroll down a bit for the softsynth part. FM is terrible, but GM music should work (sound better)
i386 16 ⇒ i486 DX4 100 ⇒ Pentium MMX 200 ⇒ Athlon Pluto 700 ⇒ AthlonXP 1700+ ⇒ Opteron 165 ⇒ Dual Opteron 856
Reply 5 of 9, by Shponglefan
psaez wrote on 2024-09-02, 19:40:
It depends on what type of music you mean.
Generally, there are two ways people remember Doom music. Either FM synthesis or General MIDI, usually the latter being a Roland sound set.
If you want FM synthesized music, the most accurate way is going to be via genuine OPL synthesis or something very close to it (such as ESS OPL emulation).
If it's in General MIDI music you're after, then the most accurate will be a genuine Roland SC-55 sound set or something very close to it.
Pentium 4 Multi-OS Build
486 DX-33 with 5 sound cards
Reply 6 of 9, by Kouwes
My first Doom music experience was with a Sound Blaster 16 (CT2230) which I bought new back then.
Then I bought a Gravis Ultrasound Max and man, that was WAY better!!
But I totally agree with Shponglefan: Roland SC-55 is the best. Or get a Dreamblaster X2GS and a decent soundcard with wavetable header.
Reply 7 of 9, by psaez
Shponglefan wrote on 2024-09-02, 21:21:
It depends on what type of music you mean. […]
Why if I select general midi in doom setup it doesnt play music?
Reply 8 of 9, by psaez
Well finally I solved it configuring the game to general midi and modifying the port to 320. Then the music is perfect and wonderful. Why you told that was not possible?
Reply 9 of 9, by zb10948
psaez wrote on 2024-09-03, 11:39:
He didn't.
There are two ways to play the soundtrack, FM and MIDI. Synthesis and samples. AudioPCI does horrible synthesis, and via emulation, but the MIDI sampler part is real with an average soundbank.
When people talk about bad sound of AudioPCI in DOS it is implied they're talking about FM.
There is no attribute "perfect" for MIDI music, you get what your soundbank is capable of. Plug in a Roland on that card, game a bit, disconnect the Roland, and then tell me is that default card sound "perfect and wonderful".
